BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2003 Malaysia ZX12r (any difference) NEW TOPIC NEW POLL POST REPLY
kiwi12
posted January 02, 2009 03:33 AM
Hi all
I have a 03 Malaysian ZX12.
Is there any real difference? hp, wise or in the ECU?
i have a bolt on Muzzy,
muzzy kleen air block of plates,
muzzy timing advancer, at 4.5
DNA air filters,
Muzzy Box
Also has anyone heard of this mod , I found it on a Aussie ZX12 forum ,
ive just copied and pasted it below..
Today i re-wired the small plug on the stock cdi under the glove box.
I was told the computer has retarded timing maps for the first 3 gears so the corresponding wires are soldered onto the 4th gear wire which has a normal timing map. This makes the bike mono easier in first and seems to have crisper response in first 3 gears.
The computer restricts the rev limit in top gear to just below 11 G, which is just under 300k with standard gearing.
To remove the speed limit the top gear wire is soldered onto 5th gear wire, letting the engine rev to normal limit in top gear.This may be helpful if you have reduced the standard gearing substantially.
Here are the instructions (thanks to Swede from ZX-12r.org)
Disable Speed Restriction
1 Pull out the CDI from it's rubber holder
2 Pull off plug marked 1425, the smaller plug.
3 on one side of the plug you will find a green/white wire and green/black wire.Free those wires to make room to work with them.Now cut the green/black wire about an inch from the plug.Isolate the wire coming from the plug.Un-isolate the green/white wire without cutting it. Solder the green/black wire to the green/white and isolate it.
Disable Torque Restriction
1 The green/red , green/blue , and green/yellow wires are to be cut an inch from the plug. (i staggered the 3 wire cuts to solder them along the exposed part of green wire)
2 Un-isolate the green wire about half an inch.You can use a lighter to warm the cable and pull the plastic back.
3 Solder the cables to the green cable.
4 Isolate and you're ready.
I found the wires located next to each other in rows on the plug.
Swede said he found this info on a german website and they had tested the mod on the autobahn.
i think it only applies for 02-03 bikes on. not sure about 04 on.
i could not buy an accessory hub for my yoshi ems to enable individual ignition maps for each gear so this evens the ignition maps before applying any further ignition timing mods across the board via the yoshi ems.
zx12B2
Newbie
what is going on in here?
jeremy_kokwk
posted January 02, 2009 04:53 AM
hey brudder, me from Singapore, where is good place to dynotune the bike in Malaysia? i heard there are shops near Sepang which do good tuning.
kiwi12
posted January 02, 2009 05:00 AM
Sorry Dude im from New Zealand,
jeremy_kokwk
posted January 02, 2009 07:06 AM
oooooooh .... then you imported a zx12r from Malaysia????
kiwi12
posted January 02, 2009 02:41 PM
IT was imported, yes
Im very happy with it,
just wanted to know if there is any difference with this model, in hp or the ECU.
I understand some countries require hp restriction,
suix
posted January 02, 2009 07:10 PM
no performance difference..
you have the muzzy box and it helps to bypass the restriction..
tuusinii
posted January 03, 2009 10:51 AM
Originally, at least in '00, Malesian bikes didn't had cat in the OEM pipe and they were rated +3 hp for power. As You have Muzzy in there that's not an issue...
jeremy_kokwk
posted January 04, 2009 12:44 AM
well , i believed only yr 2000 model is unrestricted , the rest you have to fit in some aftermkt stuffs to remove it. how much did you get it for, i met a guy to my local bike shop who claimed that motorbikes are damn expensive in NZ that why he came to Singapore as he is local, bought a honda motorbike and export it over to his 2nd home at Christchurch ..... hmmmmmm so any of your friends want a zx12r can get from me hehehehe.
Cheers!
kiwi12
posted January 04, 2009 01:25 AM
Cheers!
Bikes aren't too bad to buy here in New Zealand,
The 03 ZX12 cost me $7500 nz about $3750 us.
If i have a look around the local shops, and auction sites, and personal sellers,
the price is between $10,0000 to $15,000 nz. ($5000 to $75000 us)
My Brother buys alot of bikes/car from japan, and if you know where to get them , you do get some good bargains..
Ive just come back from Norway , i had a 4 month holiday riding around, (when it wasnt snowing)
the price of bikes over there is sooooooo high, the new Hyabusa is about $70,000 NZ ,
how much you selling your ZX12 for?
jeremy_kokwk
posted January 08, 2009 02:17 PM
i am not too sure pal, as i am not sure of what is the cost of exporting my bike to NZ, unless you can find out then we can work out a price.
0.24717307090759 seconds processing time
