BIKELAND > FORUMS > ZX12R ZONE.com > Thread: engine dolly NEW TOPIC NEW POLL POST REPLY
aliveagain
posted September 06, 2002 06:31 PM
engine dolly
I need your experience on what to use to support the motor during removal and installation and where I need to support it. does the motor have a tendacy to roll forward?
ZHooligan
Post Whore Extraordinaire!
posted September 06, 2002 09:30 PM
I have found that two guys and a floor jack work fine. I like to lay a piece of cardboard down to set the engine on and then youi can pull the engine out from under the bike. the engine is bad for balance, but because of the shape of the pan you will have to lay it on it's nose on the bench or shim it with wood.
Swft and I have both individually picked the engine up off of the Handy bike lift and carried it over to the work bench. It is a obviously not the lightest engine out there!
future; -- Youth is forever.
aliveagain
posted September 07, 2002 03:39 PM
thanx
posted September 07, 2002 03:56 PM        Edited By: VincentHill on 7 Sep 2002 17:03
I plan something a "Little" Different! I am going to buy a Transmission dolly form Harbor Freight! It has 4 wheels and a cradle that is adjustable and for around $70 you need no on else!
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=39178
It even has a Strap to help hold it in place!
ra12r
posted September 07, 2002 07:40 PM
Take the pan off first, then it will balance with a piece of wood. I disassemble the sides of the motor while it is still in the frame. Makes the motor much lighter to handle too.
Good idea Vincent!!!
posted September 07, 2002 09:02 PM
I have it down to 1 guy and a jack stand, and then once out I put it in my motor stand that I had built...
Mad Mike
Y2KZX12R
CompetitionCNC.com
posted September 08, 2002 04:35 AM        Edited By: Y2KZX12R on 8 Sep 2002 18:10
aliveagain, I have a cradle made for the zx-12R engine. It sits on a floor jack and makes removing the engine a one man snap.
I can give you dimensions so you can duplicate it. It takes about 20 minutes to build.
This is all there is too it.
I recomend screwing and clueing it together.
It also doubles as a chassis alignment jig. Its marked off within a 1/16" to align the tracking of the front wheel to the rear.
The silver lines are where the string is run and secured and weight is placed in the jig.
aliveagain
posted September 08, 2002 06:49 PM
y2kzx12r sounds good, please email me the info
NINJA12
posted September 08, 2002 07:38 PM
Just post the details here. Thanks
0.22021889686584 seconds processing time
