BIKELAND > FORUMS > ZX12R ZONE.com > Thread: A.P.E. CHAIN TENSIONER &SLOTTED GEARS NEW TOPIC NEW POLL POST REPLY
ninjafreek
posted September 01, 2002 04:13 PM
After about 6 hrs I finally have degreed my cams. But It looks like the chain is riding awafully high on the sprockets. Is this O.K.
Also setting the tensioner how tight should the chain be?
They say 1/4 play between gears in directions that shit seems to loose.
Any help would be appreciated
mrfast
posted September 02, 2002 07:26 AM
This is a great question since I have seen a lot of broken chain guides over the years on Suzuki GS bikes running manual tensioners.Maybe Jay at APE should answer this but I will tell you what has worked for me on a mid 7 sec Suzuki running .425" lift cams.Rotate engine making sure all slack is between the intake cam and crank gear,then,with gasket in place,both mounting screws on tensioner backed out app. 1/8th inch,turn adjuster in slowly while holding the adjuster body tight to cylinder.As soon as the body starts to lift at the gasket surface-STOP.Double check the cam chain by turning engine over again,and recheck the tensioner,there should be no preload on the chain.This has worked for me with no chain or guide failures in 3 years.
0.35956001281738 seconds processing time
