BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Stock Pipe Mods ! NEW TOPIC NEW POLL POST REPLY
RedBull
posted August 31, 2002 07:31 AM
Stock Pipe Mods !
Rather than Spend the big bucks on a pipe...
I put a tune-up on the stock ZX12 Titanium unit.
2 small allen bolts hold the muffler cover...
Then 4 nuts hold the muffler to the header,
1 nut holds the muffler to the rear foot peg.
With the muffler off you'll see the converter,
drill it out with a holesaw then a sawzall.
With that part out I started the bike, (loud)
I also made a pass on it to blow it out.
If you look in the muffler you'll see that it has a lot of little holes in the inlet, & 2 small holes going to the outlet.(sewing machine sound, with little air flow.)
I drilled every other hole & some straight through the center plate inside the muffler, and a few more at the top from the inlet side.
After cleaning out the shavings I re-mounted the muffler, not loud at all, no more sewing machine sound & it flows loads of air volume.
It still looks stock on the out side, but if you look into the out let you will see a few more holes that will push more volume to the outlet, & yes the bike does perform better !
I took it to a track that I could only get 180 to 185 mph before I had to shut down, with the muffler off I went 190 to the same shut off spot & realy had to put on the binders, with the muffler mods done I made the same pass thinking that it would still do 190 and to my suprise I went over 195 before I hit the binders at the same point, boy did I run out of distance for breaking !
It's amazing what an extra 15 mph. will do.
Red, *<(:{)-
1998 Prostar West Super Gas top ten.
1999 Prostar West Super Gas Champion !
2000 NMRA / Prostar Pro E/T runner up.
2001, 2002, & 2003 NMRA Pro E/T Champion !
2004 #3, 2005, & 2006 NMRA Pro E/T runner up.
2007 Pro St. Legal #6, NMRA Pro E/T Champion !
2008 Motorcycle Drag Race Assoc. SS Champion !
www.dragbike.com - www.MDRA4U.com
www.PMRcomponents.com www.NAARDEN.biz
Photos by www.HooliganUnderground.com
  Ignore this member    Click here to visit RedBull's homepage.
TReMor
Dazed and Confused
posted August 31, 2002 08:07 AM
Good work, man!
Check out this LINK for that and other mods that might help you in your quest for more stock powah!
Tim
  Ignore this member    Click here to send TReMor an AIM message.
ZHooligan
Post Whore Extraordinaire!
posted August 31, 2002 09:25 AM
I would assume that the work listed above is the prep work for reinstalling the defective equipment. Afterall any modification of that equipment is afterall against the law. Hopefully the parts and pieces will be delivered for their installation sometime in the future.
Remeber it is all about the children and safety.
"Earth first, we will pave the other planets later."
future; -- Youth is forever.
posted August 31, 2002 11:23 AM
Congrats and welcome to 2 1/2 years ago.
I always recommend that mod to those who want a *slipon* type muffler. The stock "bazooka" polishes up nicely and keeps noise to a minimum. Problem with the stock exhaust, other than weight, is that it chokes the bike at higher rpms...which you have obviously found out! But $ for $, exhuast replacement is the best mod for power!
beansbaxter
posted September 01, 2002 09:26 AM
Redbull....curious on how many miles were on your 12 before you decided to do this??
I've got over 7000 miles on my 02, and the stock exhaust has gotten progressively louder the more miles I ride on it. A lot of friends I've riden with all notice that the pipe is getting a lot louder.
feldguy2002
posted September 02, 2002 05:27 PM
I cut the pipe off, then put on a Micron Serpent. All in all, the Serpent is ridiculously loud.......which is good.
RedBull
posted September 15, 2002 07:16 AM
Bean the 12 has less than 5,000 miles on it...
Hey Tim, thank you kindly for that link...
Turbo Blew, Some of us are new to this site, as you can see by the # of posts...
Never the less, we get just as excited as feld guy to get free horse power...
The National Motorcycle Racing Assoc. is having a race in Las Vegas Oct. 5, 2002
It would be cool to go out there & race with them, the gate open at 7:00 AM.
Arizona Charlies East is host hotel, Mention Airtech Nationals for $51.00 room.
They will be having a bike show there on Friday Oct. 4, 2002 www.NMRAonline.com
Red, *<(:{)-
ra12r
posted September 15, 2002 08:14 AM
If you want more HP just do all the Y2k mods...... Go to easy's site and download the entire sheet.
jonwright
posted September 27, 2002 07:04 AM
I have the Nikko Racing pak on my 12. Supposedly it changes the fuel curve and advances the timing (I think).
Would tweaking the timing interfere with the box? What if I had a power commander? Would I tweak the timing using that?
Where would I go to begin research on this?
Any help for this dumbass is appreciated...
Thanks,
j
'02 12 3,400 miles
Eddyirish
posted September 28, 2002 06:49 PM
Been there & done that! None of the suggested mods are worth doing except removing the CAT and going for a full exhaust or slip on. The stock can is worthless & canot be modified to produce more power! Trust me!
  Ignore this member    Click here to send Eddyirish an AIM message.
0.22389507293701 seconds processing time
