slarpo909
posted October 11, 2008 06:16 AM
bike running rich
got a 00 12r 30,000 miles, running very rich.new plugs air filters still the same. any suggestions on what the problem may be thanks
harpo
NOX
PMRA / TMRC Super Street 4022
posted October 11, 2008 06:45 AM
Lean out the map.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
slarpo909
posted October 11, 2008 06:49 AM
thxs nox how do u go about leaning out the map.what do u need to do this.
harpo
kaw12
posted October 11, 2008 11:59 AM
how do you know its running too rich?
slarpo909
posted October 11, 2008 01:48 PM
plugs were black . had one foul out. the can/exhust pipe is carboned up.
harpo
posted October 11, 2008 03:15 PM
If you have a Power Commander Disconnect it, it may be bad...
RidgeRacer
posted October 12, 2008 07:09 AM
If you don't have a power commander the problem could be a bad inlet (IAP) or static air pressure sensor (SAP). If you turn the bike on, (don't start it) and measure both voltages they should be the same. (See the manual)
2000redrocket
posted October 12, 2008 04:12 PM
so do you have a power commander? did this just happen? is it so rich it will not run correctly?
mine was so rich it would not run correctly and then killed the plugs. it was the map sensor.
