BIKELAND > FORUMS > ZX12R ZONE.com > Thread: air filter NEW TOPIC NEW POLL POST REPLY
Liquid Rhino
Loving Life! God Bless!
posted October 08, 2008 07:15 PM
air filter
Its time for the air filter to be removed/ changed. I took off the gas tank cover and I lifted the gas tank. I took the screws out of the filter and the damn thing won't come out. Can anyone out there give me some assistance on what to do to get this taken care of? Thanks-
tuusinii
posted October 08, 2008 10:08 PM
You probably have K&Ns there? They do get stuck! Use a long screwdriver to get them gently off. Or if You're goingto replece them You don't have to be gently. How much miles do You have? You could just clean them..
NOX
PMRA / TMRC Super Street 4022
posted October 09, 2008 06:49 AM
what are these "air filters"????
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 09, 2008 08:16 AM
Im probably the last guy out there DragRacing a 12 using stock air filters, no Power Commander and foot shifting
big al
posted October 09, 2008 09:13 AM
A little wd40 will help them come out without ripping the snot out of them. You can also use or make the same type of tool you use for the exhaust springs. Put the wire hooks in the bolt holes and gently pull so you don't rip them. Before you reinstall the filters if they are k&ns you can sand the rubber down a little on a plate of glass so they fit a little better. Thats what I did till I got the bmc's
posted October 09, 2008 12:36 PM
With K&N I had to use a Sears Cotter Pin Removal tool (Hooked at the end) and had to pry in the Airbox under them! Also if someone tightened the Stock very tight (The Bolts) then you will need to bend the Frame Opening back a little to get them out.. I used a spcket and screwdriver to carefully widen the uprights where the Filters Bolt in. Also I used a big Phillips to push the Filters up through the Bolt Holes. In other Words, do everything you need to! Heavier Oil than WD40 will beed to be used!
0.25137495994568 seconds processing time
