BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Risers NEW TOPIC NEW POLL POST REPLY
vmaxwayne
posted August 25, 2002 03:04 PM
Risers
Has anybody installed risers on an 01 ZX12R??
The top calmp includes the key and so has to stay??
Perhaps shims under the triple.
Also dog bones to lower the height??
Wayne
rs
posted August 25, 2002 03:09 PM
Installed Heli-bars on my 00 12R and it made quite a bit of difference.
vmaxwayne
posted August 25, 2002 03:40 PM        Edited By: vmaxwayne on 25 Aug 2002 16:40
With the bar clamps as part of the top clamp how did you fit the Heli bar clamps??
I want to lower the bike ~1" and so I'd like to slide the forks up and get a dog bone to lower the rear by the same.
rs
posted August 25, 2002 03:46 PM
The Heli-bars just fit in place of the OEM handles. They have an off-set that raises and brings the grips a little closer. I may have misunderstood what you were looking for.
posted August 25, 2002 04:24 PM        Edited By: VincentHill on 25 Aug 2002 17:26
Go to Doug at Spencer Cycle! You can get them in 3 rises! I have the 1.5" rise! You disconnect the wiring for the Switch, remove the Bolt that holds the handle bars in place and after removing the top clamp, drill the 2 bolts that hold the ignition in place and he supplies new bolts! If security is your worry, buy new Kawasaki twist off bolts and remount your switch! Price is about $265.00 plus shipping! Look at his site it is machined form billet and a beautiful peace of work!
BTW, from reading your post, it does not look like you have a shop manual! It is a necessity if you are going to do any work on your bike! "A Picture is worth a thousand words!"!!
TedG
posted August 25, 2002 04:51 PM
Into ape hangers now??
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
vmaxwayne
posted August 25, 2002 05:43 PM
As I understand the Heli bars clamp to the forks, have a riser and clamps for new bars.
What about the ignition key isn't it a part of the top clamp??
rs
posted August 25, 2002 05:58 PM
The Heli-Bars use the factory mounting bosses and just replace the straight piece of pipe with an off-set one.
vmaxwayne
posted August 25, 2002 06:10 PM
What's the URL reference for Spencer cycle, went there couldn't find the risers.
Is the key not part of the top clamp. And No I don't have the manual as yet but soon.
SpencerCyclecom
posted August 25, 2002 06:42 PM
Doug
SpencerCycle.com
1-800-510-1945
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
vmaxwayne
posted August 25, 2002 07:45 PM
Doug:
Thanks, I'll be back to you.
Wayne
EastBayDave
posted August 26, 2002 06:30 AM
Vince,
I donno if I asked this b4, but how about cable/brake line/wiring length? As you now have the 1.25" additional rise, I'd be worried about length of everything...? Did you have to do any mods?
Dave
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
spencercyclecom
posted August 26, 2002 07:31 AM
We sell s/s lines that may be used with this part. But we have had some custormers use their stock lines. From what we understand they are removing the bolt from the juction block on the lower tree and this is giving them the length they need.
Doug
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
posted August 26, 2002 07:35 AM
Vince,
Dave
I redrilled the hole that Positions the Throttle cables forward 1/8" so that the cables clear the the fairing! I moved the Clutch lever as far inward as possible for more leverage and a little length! (Re adjust the amount of play!) as for Brake lines, I have Goodrich I had to cut the bracket on the lower tripple clamp to remount the plastic! My feeling anout stock is "Somehow" you must disconnect the mount on the fork to give the line more room!
spencercyclecom
posted August 26, 2002 09:16 AM
Just a note.... The units we have installed in the shop we have NOT had to drill and reposition the throtlle. The unit is designed to work without doing anything of this nature.
THESE WILL NOT FIT THE 2002 MODLES---AT THIS TIME!!!!!
Doug Ray
SpencerCycle.com
Fax 1-704-642-0987
vmaxwayne
posted August 26, 2002 03:00 PM
Anybody have any photos of the Heli bar setup. the one on the Heli bar site sucks.
I'm trying to decide on the spencer or the Heli bar, $100 differnence.
Also any one changed out the dog bones to lower the zx??
How low did you go??
TIF
Wayne
posted August 26, 2002 05:34 PM
I have the 1.5 rise! WIth the moving of the throttle cables, I have full lock to lock and "Just" clear the upper fairing mount!
0.21859502792358 seconds processing time
