BIKELAND > FORUMS > ZX12R ZONE.com > Thread: LP Titanium Exhaust Hanger Question NEW TOPIC NEW POLL POST REPLY
beansbaxter
posted August 22, 2002 04:26 PM
Hey I just installed a Lockhart Phillips Titanium Exhaust Hanger, came in today. The guy I purchased it from said it came off a 01 12, and my 12 is an 02 model. According to LP's website, the same part works on all three years of the 12.
It seems to fit on, but its hard screwing in the bolt on the exhaust end. I eventually got it tightened up but the exhaust is now barely touching the swingarm. I'm not concerned that the exhaust will get bent, but I just wondered if this is ok??
Is there a spacer I should maybe use or a longer screw or something else to screw the hanger in to the exhaust? By the way, my exhaust is still stock if it matters.
Also, when I removed the foot pegs off the left side, what should I use to fill those holes? Or should I just leave them bare?
Thanks for any help.
zx12sleddog
posted August 22, 2002 04:33 PM
Daniel it is a self locking nut on the end of that bolt on the exhaust end. The holes on the left side is were the other end of that bracket goes. I was using the Muzzys full system with the round can.
Tony
Dino
posted August 22, 2002 05:01 PM
Beans, for the left side,...shorten the bolts enough so they don't dig into the plastic, and screw them back in!!!(doesn't look too bad)
uh oh
Phil
posted August 22, 2002 09:21 PM
Found some rubber plugs at an auto store that fit the holes perfectly, even looks factory.
0.21450304985046 seconds processing time
