BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Billet Cranks? NEW TOPIC NEW POLL POST REPLY
shane661
posted August 23, 2008 08:52 AM
Billet Cranks?
Does anyone still make a billet crank for the 12R? The Muzzy unit is apparently no longer available.
Just curious.
posted August 24, 2008 11:34 AM
Check with Orient Express, they may still have a source.
posted August 24, 2008 09:39 PM
Shane,
i burned up one o those billet cranks (my fault), but have been happy with weld up strokers since then.
what is making you interested in billet?
NOX
PMRA / TMRC Super Street 4022
posted August 25, 2008 05:11 AM
Karl, I did not know that...., you have been making those motors live with the welded strokers..........
Interesting..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
shane661
posted August 25, 2008 05:13 AM        Edited By: shane661 on 25 Aug 2008 06:14
I had read something awhile back about the design of a billet stroker vs. a weld up, and longevity.
But I am sure that a weld-up is fine. I was just curious as to the options out there. I doubt I will end up with a stroker, but it's good to know all of the options.
So Karl, you have a welded stroker...60mm? By Marine Cranks? And the Muzzy Billet offset block, correct?
posted August 25, 2008 05:42 AM
yes and yes
my stroker crank is offset to match the muzzy offset block
shane661
posted August 25, 2008 06:14 AM
I didn't know it was possible to relocate the journals? So, the counterweights are then built up/machined to allow this?
Sorry if that's a dumb question, but I don't know anything about crankshafts..
posted August 25, 2008 09:38 AM
It sure ain't a dumb question...
I didn't know that you could offset cranks until mountainmotor told me to ask Marine if they could do it.
Marine said "sure, we've been doing them for Muzzy for some time"
After all the wrist pin and piston issues i had been having i gotta wonder why why didn't Muzzy tell me???
Since i started running the offset crank, my pin problems disappeared.
shane661
posted August 25, 2008 09:47 AM
So this allows you to run "standard" pistons, without the offset?
Sounds like a great solution to a design compromise. Why not get it done if you are getting the crank stroked anyway, right?
posted August 25, 2008 02:36 PM
was it much more to offset the journals Karl? so if you burn one up again, you are going to go all out with a 63mm stroker right? you know you want to. and can, Wolf did :P
posted August 25, 2008 03:06 PM
the pistons which come with the billet block kit are not offset, and the sm end of the rods was rubbing on the inside of #1 & #4 pin bosses.
As the kit comes from Muzzy, the rods don't center on the pistons.
Offset rod journals solve that, but then the #4 rod big end hit the clutch drive gear. trimmed that and all (now) is well.
Cost isn't much more than standard weld-up stroker.
Big learning curve for me, yep.
NOX
posted August 25, 2008 03:58 PM
Wolf uses a starter cart for the pro stock bike I am sure.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted August 25, 2008 05:00 PM
ahhh theres the kicker. i wonder if a 5mm stroker is the limit for using the stock starter setup? i bet you could make something on the end of the crank to use an onboard starter for the 7.6mm stroker though....
NOX
posted August 25, 2008 08:14 PM
I think 5 mm is the limit.........
I also wonder why they chose stroke over bore..........
Best gain in hp, is big bore, short stroke.........., look at the piston size of the pro stock cars, and that tiny stroke they have........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted August 26, 2008 04:43 PM
you would need to offset the bores more, and then offset the combustion chambers so you would pretty much need a billet head right?
aliveagain
posted August 26, 2008 05:32 PM
Over 5mm,I would think you would have to use a different cam chain.On the A models it also would have a problem with the front engine mount.
posted August 26, 2008 05:46 PM
that depends on rods and how much you have the head or block milled too. you can run shorter rods so you dont even need a base spacer, but longer rods last longer
posted August 26, 2008 08:56 PM
Billet head needed
Cam chain problem
Special cam blanks needed
Clutch and Starter gear problem
Special crank/cam drive needed
Case clearance - big problem
Lots of problems trying to grow bigger than 1460
Uh, why do longer rods "last longer"?
posted August 27, 2008 12:48 PM
from what I have been told by guys smarter than me, you want to keep the rod to stroke ratio high(i may have worded that wrong) for the best life of either rods or bearings (not sure which, but im guessing both?) the shorter the rod, the more of an angle it has to go.
posted August 27, 2008 02:28 PM
Well, sorta.
The variance of posssible rod lengths in a given engine is pretty small- up to 10 millimeters max is about all there is room for. Given how strong good rods are, that amount of rod angle change matters little. Where rod length vs mechanical loads most definitely DOES matter though, is piston skirt loading and the resultant friction. The longer rod giving less load to the skirts. One thing that rod length really effects is the dwell time of the piston and the acceleration / deceleration rates of the piston and the amount of time it is "stopped" at TDC. Things like fuel burn rates, ign timing and cam timing need to be optimized to benefit from rod length changes. All of that means torque curve changes with rod length changes, which is usually why rod length changes are made.
ninja12
posted August 27, 2008 10:39 PM
over 5mm you will have major case interference on 1 and 4.
wolf racing
posted August 28, 2008 12:11 AM
NOX - Starter cart on the Pro Bike. On board starter for the 1427cc no problems.
entropy - we've always used offset cranks and never seen any of those other problems.
aliveagain - we still use a standard cam chain on the 1498cc.
To me, race engine and last longer just don't seem to fit together!!!
Never Ever Give Up
  Ignore this member    Click here to visit Wolf Racing's homepage.
posted August 28, 2008 04:40 AM
quote]
yep, i just wish Muzzy had told me to offset the crank from day one.
grrrrrrrrrr
shane661
posted August 28, 2008 04:51 AM
One of the advertised selling points of the 1317 block is that you can just bolt it on without disassembling the lower end. Like a weekend job:
"It's been said that there's no substitue for cubic inches (or cc's!). You can now add those cc's to your ZX-12R with the Muzzys Billet Big Block without splitting the cases."
It doesn't sound like a good idea, though.
posted August 28, 2008 03:25 PM
I don't recollect that the 1317 is an offset block. It is simply a billet big block with concentric 87mm cylinders. Right Karl? In its original form you had to clearance the cases for the lower portion of the cylinders. Later we modified that so it was stricty a "top end" change. Actually, like you put it ,"a weekend job".
The next larger block was the offset one.
0.23712992668152 seconds processing time
