BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Swingarm Swap NEW TOPIC NEW POLL POST REPLY
gsxrassassin
posted August 07, 2008 06:22 AM
Swingarm Swap
Another member has a black swingarm from an '05 ZX-12R that I'm very interested in. Problem is I have an '00 model and I don't know if the later model swingarm will fit the older bike. Does anyone know if the swingarms were interchangeable across all years? Thanks.
GSXR
Over the hump, back up and running again!!
puppy
Lifes a bitch then you die!
posted August 07, 2008 11:41 AM
I have an '06 swing arm on my '00. No problems swapping, but I would use the dog bones from your '00, otherwise your ride height will drop!
Photobucket
Photobucket
twista
" Get up, and Stay up ! "
posted August 07, 2008 02:15 PM
yep,, my A1 is wearing a 05 arm,, gotta use the caps or castle nuts off the 00! straight swap,, might have a chain issue if its stock,, might have to pull the front sprocket,, i just filed a little off the inner area of the frame,, not even an 1/8 inch...
gsxrassassin
posted August 07, 2008 02:23 PM
Thanks!
GSXR
0.29429292678833 seconds processing time
