BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Idle is getting rough... NEW TOPIC NEW POLL POST REPLY
james9793
posted August 03, 2008 07:30 AM
Reposting from LABusas.org...
I have a 2003 zx-12r with 5300 miles.
It has full Akro with PCII usb. The map is excellent; no flat spots or stumbles. Bike flat hauls when I want it to.
Ive owned it for 2 months and put 2000 miles on it in that time.
I've noticed over the last couple of weeks that the idle is getting rough, and I have to fiddle with the mixture screw to keep it around 1K rpms; especially when cold, but even on a hot restart. Bike still runs great under throttle.
What is going on? What needs to be tweeked or replaced?
Can anyone help me out? The FSM hasn't revealed much.
James
posted August 03, 2008 05:58 PM
maps can get corrupted. might want to do a quick check?
screws by the TPS loose?
is your fast idle lever working?
posted August 03, 2008 06:38 PM
Can you be a little more specific/descriptive on what you mean by "rough"?
maximus
posted August 03, 2008 11:22 PM
Also stick to those basics, Plugs and wires, valve adjust,
brickman
posted August 06, 2008 07:38 PM
this may sound crazy but check for rust in your tank.
posted August 07, 2008 03:04 AM
another 1 post wonder...
posted August 07, 2008 06:33 AM
Well we tried.......
james9793
posted August 07, 2008 09:41 AM
Guys, I appreciate the responses.
Sorry I haven't gotten back, but I've been way too busy at work.
When it starts, the RPMs are signifigantly lower than 1K, it sounds like a Harley; this is what I mean about a 'rough idle'. I have to use the fast idle to make adjustments.
Seems to be getting even worse because, when I started the bike (full choke) this morning for the commute, it died twice. This hasn't happened before.
I need to look at my map to see if it has corrupted as suggested above.
I keep the gas tank full if parked for more than a few days, so I don't think it's rust.
James
posted August 07, 2008 01:57 PM
turn the idle screw in... idle the bike around 1400 rpm. oil pressure is scary low at 1k
BONDGUY399
posted August 07, 2008 02:22 PM
Well i was having idle issues of it revving really low, and sputtering and dieing, but it only actually died when cold. When hot i was having alot of surging at idle, and if i were to rev it to say 4k it fluctuated alot. Syncing my throttle bodies did the trick for me. I was having a hard sputter at low rpm before that and plugs solved it.
I'd start with the cheap options and work your way up lol.
2000 ZX-12r
posted August 07, 2008 02:46 PM
Some food for thought:
Your fast idle is not a "choke" it does not effect A/F, only throttle position.
Have you checked your idle stop screw? Could someone have messed with it?
Is that what you're referring to as "the mixture screw"? There is no mixture screw, only
air bypass screws on each throttle body (normally sealed off).
Check all the small hoses from the throttle body spigots. Any pinched or off?
Is the KLEEN air injection system intact? Any hoses off?
What is your battery voltage at idle? Anything less than 12.5 or so at idle is not good. this can allow the plugs to foul.
Check the plugs. If they are sooty, idle can suffer.
Like KZ said, raise the idle a bit. I like 1200.
Doug
james9793
posted August 07, 2008 04:44 PM
Thanks for the additional suggestions.
I rechecked the map this afternoon; there wasn't any difference between my master copy and the bike copy. I downloaded a new map from PowerCommander; loaded it in, revved the bike a couple of times. Idle sounded a little better, and then I reloaded my master copy. Not sure if anything really changed, I'll find out in the morning and post the results.
The battery is less than a month old. I will have to check it for myself at idle.
I will increase the idle rpms to 1200, also.
I have thought about getting the valve adjustment done early; the bike has 5400 miles.
James
posted August 07, 2008 05:46 PM
pull out a plug and take a pic for us
BONDGUY399
posted August 08, 2008 08:05 AM
is the low idle really that big of an issue? I've not been able to find anymore info on this topic. I had mine set to idle about 800. and it sits there stable and happily. but am i raping my motor? lol
2000 ZX-12r
posted August 08, 2008 11:03 AM
No. People tend to get freaked out when they put a guage on the bike and see the low oil pressure. It's quite normal and the loads are so light that no harm is done at idle. Pretend you didn't hear about it and you'll be fine.
BONDGUY399
posted August 08, 2008 11:57 AM
thats what i thought. On my car its the same, at idle my pressure drops in half. But was told thats normal. Thanks Doug!
2000 ZX-12r
posted August 08, 2008 02:28 PM
hey Doug, what about Karls motor?
0.29142594337463 seconds processing time
