ZX12ZX11
posted November 06, 2001 01:33 PM
Caps or No Caps? That is the Question. Help Fish.
Sometimes when I edit a post or reply my name must either be in Caps or in lower case. Whats up with that? Also look on the right side Last Date Posted my name will appear in upper case and in lower case. I don't have two user names. My user name and password are automaticaly put in and it still happens.
posted November 06, 2001 01:37 PM
hmmm... I'll leave this one to freek or maddog to answer....
frEEk
posted November 06, 2001 08:42 PM
the case depends on how u logged in. ur username is case insensitive, but when u post, the system takes ur name from the cookie written when u logged in, which takes its case from what u typed in when u logged in. so log in with the case as u want it to appear. the edited by type of generated text may take it from the system & not ur cookie, not sure.
zx12zx11
posted November 07, 2001 10:16 AM
I logged in under the name ZX12ZX11. But it randomly goes between both upper case and lower case. Hell I don't know what to do. I'm still confused.
frEEk
posted November 07, 2001 08:54 PM
in that case im at a loss too. i control my case by how i log in as. never gone awry [sp?] on me
zx12zx11
posted November 08, 2001 09:27 AM
A good case in point would be the two threads above my user name. One is in caps and the other is in lower case. Still the same number of posts, same person. WTF?
posted November 08, 2001 09:33 AM
Edited By: fish_antlers on 8 Nov 2001 09:37
he is saying yes.. it is the same person as the system is NOT case sensitive for usernames... therefore you could not register the username Y2K and y2k as they would be recognized as the same by the system, but you could LOGIN as either.... and the name you login under determines the displayed screen name when you post... therefore if you want your screenname to be displayed in caps then make sure you login in caps... and if you have a prob and it displays it mixed then at somepoint you logged in in lower case and this was noted in your cookie... to resolve this try deleting the cookie and then login in caps as the case sensitivity is stored in your cookie..... I think this is an accurate translation of freek's rambling rambles
ZX12ZX11
posted November 08, 2001 09:40 AM
I have only logged in once. Since then the Cookie has done it for me. I'll try logging off and see what happens.
ZX12ZX11
posted November 08, 2001 09:47 AM
Well in the post reply screen my user name is in caps lets see what happens this time.
