BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Nitrous kit i got for my bike NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted July 25, 2008 07:45 PM
so i jus got done installin my NOS (nitrous oxcied system) and while i was wireing it for the horn to use the nitros. everything was ok when the bike was off. one side of the switch was for the horn like it should and the other side was for the selinod for the nitrous. then when i started my bike when the switch was on the horn side the horn worked like it should the when i switched it ova for the nitrous the horn honked but it was very soft and the nitrous selinod was clickin so it is workin
and advice would be great thanx in advance
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
posted July 26, 2008 05:32 PM
Sounds like you may have a bad switch that isn't isolating the two circuits. If you can check it with a meter or test light without the horn and solenoid hooked out it might help figure it out.
0.23264288902283 seconds processing time
