BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ping VH NEW TOPIC NEW POLL POST REPLY
posted June 15, 2008 12:50 PM
ping VH
did you get my PM?
thx!
H2 to ZX12
two stroke power
posted June 15, 2008 01:18 PM        Edited By: H2 to ZX12 on 15 Jun 2008 14:20
You got to spell his name out. He's old and won't see just his initials :P
Like HEY VINCENT!!!
  Ignore this member    Click here to visit H2 to ZX12's homepage.
posted June 16, 2008 02:09 PM
bump :P
posted June 17, 2008 04:09 AM
I think H-2 may have something here!! REMEMBER I AM OLD and Initials do not mean much! PTV??
posted June 17, 2008 02:21 PM
yes sir!
posted June 17, 2008 05:51 PM
yes sir!
So tell me what is PTV? (I know PIA and PPV and PTA)
posted June 18, 2008 06:00 PM
piston to valve clearance
posted June 18, 2008 06:12 PM
Good Question which can change with Cam timing. I want 0.060 intake and 0.080 on the exhaust I am afraid of less than 0.040. More is Better. Remember I have a Low compression engine closer to a Turbo engine and my clearance is even more!
There is a little Bounce in the valve that you cannot measure and there is a little leaping of the piston at TDC which you also cannot measure. The one valve I am most afraid of is the Exhaust because the piston is trying to meet it before it closes (WHich I have had happen on a few occassions
On my 2 valve KZ1000 race engine I could sometimes see the Pattern where the carbon was "Dusted" from the top of the piston at the end of a long race. That caused me to start using a manual cam chain tensioner
posted June 18, 2008 06:26 PM
So Vincent, what was your method of checking it? did i read and old post saying that you put solder thru the plug hole?
posted June 19, 2008 03:25 AM
ONLY on the "2" Valve engines! The 4 valve engines (even with the Soft hollow core solder may hurt the valves (Do not ask)
Now I am like everyone else using a Used head gasket and Modeling Clay (A Small dab) on Each and every Piston Pocket (Again I have found that this also checks the Pistons because even with the Same valve clearance the Pistons can be slightly different along with the Height of the Valve seat! There is a LOT of things that can effect the clearance and never Assume that what you have on one will be the same on ANY Other Piston!!
I have had to take the head on and off Sevral times and it gets tiring!
posted June 19, 2008 04:18 AM
thank you for clearing that up
posted June 19, 2008 07:05 AM
Also after putting a small dab of Modeling Clay on each piston valve pocket also put a drop of Oil on the also to make sure they do not stick to the Valve.
Depending on when I posted about that soft hollow core solder I tried that about 2003 and discovered that it is Possible to bend a valve slightly! The stuff I was using I could Shew with my teeth so I was Surprized!! so for when I made major changes in 2005 I went back to the "Old" Ways!
My next test may be to use a thin piece of Safety wire with a dab of Clay but then the wire could get caught up between the valve head and the seat! Just no easy way I know of right now!
posted June 19, 2008 08:04 AM
ask Karl about Tims fancy ptv tool... probly expensive tho
posted June 19, 2008 01:15 PM
I KNOW what they do! He depresses the Valve and uses a dial indicator to see what the clearances is! I have all of the Dial Indicators in the world but no "EASY" way to depress the Valves without having light springs! That covers all of the problems!
KARL!!!!!
posted June 19, 2008 01:54 PM
im still not exactly sure how its done, but i was thinking about using 1 piece of a stock EX valve...
my motor should be back together tonight with gapped rings(thx for the numbers JC) and im borrowing a dial indicator and degree wheel tomorrow to set cam timing, and hopefully ill be able to check ptv
0.24359703063965 seconds processing time
