BIKELAND > FORUMS > ZX12R ZONE.com > Thread: hands going numb after 30 min of driving NEW TOPIC NEW POLL POST REPLY
johnnnyboy
08 Concours 14
posted May 19, 2008 02:55 PM
whats the best fix for this ? will gel grips make a big difference.
I dont lean on my wrists just seems like the 12 vibrates more or some thing than my other bikes.
Texas12R
posted May 19, 2008 05:27 PM
Heli Bars.......
Just my .02
aliveagain
posted May 19, 2008 07:35 PM
I started with gel gloves but after awhile it wasn't even an issue.
posted May 20, 2008 09:48 AM
Several things, #1, get 2 pair of the Gel Race Grips! Use the Left side Grip on BOTH SIdes of the bike. The throttle is thinner and you have to hold on to that one and it will help! #2, do you have the STOCK Bar weight ends or some aftermarket? If you have stock go to a bigger weight like the Old Kawasaki Concourse. Last, loosen the rear engine mounts and make sure the spacer mounts are TIGHT then tighten everything up again!
chevelle
posted May 20, 2008 04:31 PM
Check to see if the front tire is cupped.
tshultz
posted May 20, 2008 04:36 PM
gel gloves work really well. Never herd of the gel grips I might have to try them.
posted May 20, 2008 11:41 PM        Edited By: VincentHill on 21 May 2008 00:43
http://www.motorcycle-superstore.com/1/4/312/MANF/Shop-By-Brand-Pro-Grip-Street-Bike.aspx
Pro Grip
699 Open End Sportbike Gel Grip
$8.99
Like I posted some where else I use 2 pair and use the Left side on Both sides because the Left side is thicker and you MUST hold on the the Throttle so make it have more insulation
tshultz
posted May 21, 2008 02:08 PM
Thanks for the link I going to have to buy those.
pcbunn
posted May 21, 2008 02:50 PM
Try not squeezing the bars so hard.
Phil
lobo
posted May 21, 2008 08:51 PM
i did a few things that helped, we usually ride a 300mi loop. 1. take 1 aspirin before ride, then around every 4 hrs, helps circulation, this works. 2. grip puppies-neoprene covers that slide over grips 3. throttle rocker, made one. 4. do this at your own risk, i have a 01 zx12r, don't know about other years, i removed the one throttle return spring under the pulley were the throttle cables connect to the throttle bodies, take off the nut and the pulley and theres a spring under it, remove spring and put back together, mine springs back just fine without it, if yours doesn't put spring back on , much easier throttle pull, helped the right hand alot, i did this a year ago and never had any problems, the only thing is you have to get used to the lighter pull, especially in first gear (she can turn into a bucking bronco). i bought a set of heli bars and never installed them, all this seemed to work.
johnnnyboy
08 Concours 14
posted May 22, 2008 02:02 AM
i think gel grips seems the way to go right now thanks guys
Wildman
I only look confused
posted May 25, 2008 06:42 PM
Throttlemeister helps
If you build something Idiot Proof, The world will build a better Idiot.
slug
Out in search of my mind...
posted May 25, 2008 08:07 PM
+10000
if you can't flap your elbows like a bird flapping its wings, you're putting too much weight on your arms and not enough on your abdomen
A relaxed grip on the bar is the best way to clear the numbness. Because even with heavy bar-ends and gel gloves, a tight grip will just force the vibration into your bones.
tooo slow 4 u
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
lietoome
posted May 26, 2008 06:14 PM
Helibars were one of the best investments I ever made with my 12. It made a HUGE difference to me. See if you can pick up a used set, Lobo? You won't be disappointed.
tshultz
posted May 27, 2008 04:36 AM
Helibars were the first aftermarket product I put on the bike.
They work great well worth the money.
ninja12
posted May 28, 2008 06:17 AM
Some pipe add a lot more vibration than others.
What pipe do you have? stock or akrapovic are the smoothest for me.
johnnnyboy
08 Concours 14
posted May 28, 2008 07:41 AM
ive put a stepped tube race hindle pipe on and the bike doesnt vibrate as much at 4000 4500 seems a bit better but ill try the gel grips
princesskiwi
MISTRESS of SMACK
posted June 17, 2008 08:44 AM
+10000
pilates
The dose differentiates a poison and a remedy....
twista
" Get up, and Stay up ! "
posted June 17, 2008 01:55 PM
HELI BARS AND A CORBIN SEAT! end of story!
posted June 19, 2008 03:29 AM
Do you have the Stock Bar weights? Consider getting a Larger / Heavier Set to Quell the vibration
Also do the Check on the "Balancer" the clearance may need tightening! (Read the Service manual for this)
A Hard Ass Corbin will increase the vibration in your behind
johnnnyboy
08 Concours 14
posted June 19, 2008 05:29 AM
ya there stock maybe ill machine a set at work out of stainless or densite densite is for specificaly reducing vibration in tool holders ill try that. Plus im just waiting for the gel grips to come in.
H2 to ZX12
two stroke power
posted June 20, 2008 06:06 PM
+10 I love my heli bars. I bought a set here used for $100. I've made all day rides and no problems, getting close to 50 yo and have my share of elbow/shoulder injuries.
Order the heli bars, it takes 2 hours to install (OK i'm fucking slow :P )
  Ignore this member    Click here to visit H2 to ZX12's homepage.
0.33067417144775 seconds processing time
