BIKELAND > FORUMS > ZX12R ZONE.com > Thread: mesuring stackhight on cclutch NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted May 26, 2008 05:38 AM
lastnight i took out the thin plates and put in normal frictions and decided to see if my digital calipers will go from the back platetab to the front plate tab. it worked. now i need to shim it again. im at 56.75mm. i may of been on the short side of spek.is this howu guys do it. i found doing it seperat plate after plate is notso good to me anyway cause the frictions can vary at the three different places i have to average the thickness.
come to think of it i guess i need to figure out how thick the material is cause i am only on the aluminum tabs.so maybe i am in speck.
posted May 26, 2008 02:11 PM
i measure each fiber in 3 places(on the pads that slowly wear away), then add them all up plus add the steels, but you can just do the whole stack if you compress the anti chatter rings
2000redrocket
posted May 26, 2008 04:14 PM
i just took out the chatter rings and the two small friction discs hopeing the extra surface area allows it to hold the power better.i do not know if this was smart but i heard people do that so i am going to try it. we will see i'll try to see if i can slide it when i am done.
NOX
PMRA / TMRC Super Street 4022
posted May 29, 2008 05:38 AM
Bad move.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
tshultz
posted May 29, 2008 01:51 PM
Your clutch has two small friction discs? Is this because you have a Barnett clutch not oem?
And nox why was this a bad move.
0.25634694099426 seconds processing time
