BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Fast By Gast Battery NEW TOPIC NEW POLL POST REPLY
mack
posted August 05, 2002 03:08 PM
Has any body tried installing this battery,how much modifing is needed.It has over 500 CCA.It sounds like a good stroker motor battery.I sometimes have a hard time starting the 1361 when it gets hot.
ZHooligan
Post Whore Extraordinaire!
posted August 05, 2002 03:23 PM        Edited By: ZHooligan on 5 Aug 2002 16:51
Have not ried any new type of battery. We have retarded the timing 4 degrees at zero throttle and since then my stroker starts hot. It might turn over slow but it starts!!!
future; -- Youth is forever.
madmike
posted August 05, 2002 03:26 PM
Entropy did one, and that battery is a strange one, it does not have 500 CCA it has 500 HCA, Hot Cranking Amps. which is a 5 second burst of power above a standard battery after that initial burst it will supply the standard load as a regular battery. I believe that Entropy enjoy's his but I have never had any problem's with my Interstate Battery, and it is in it's Second season!
Mad Mike.
mack
posted August 05, 2002 04:59 PM
madmike
what is the part # of your interstate battery.
posted August 05, 2002 05:01 PM        Edited By: entropy on 5 Aug 2002 18:04
The FBG battery certainly does the trick for hot starting a built motor, BUT on the other hand, the Interstate battery prolly comes with a cool calendar, a few of which (the collector editions) are autographed by MadMike his own self!
Installation...
It is substantially bigger than the stocker but does fit into the battery hole after modifying the tray and re-routing some wires, cables. Definitely not "plug n' play"
ra12r
posted August 06, 2002 06:52 AM
I too have installed the FBG. The tray requires the remove and replace the bracket that hold the wires and plugs. But after that it fits fine...i think it is a good mod if you need the starting help.
madmike
posted August 06, 2002 07:14 AM
YTX14BS, that is the interstate #, I am also working on a larger battery setup, for the Interstate, I just do not have it finished yet. but mine has never even been hard starting. Mack, where are you at I might be able to make a phone call and get you at least a discount.
MM
kawachan
posted August 06, 2002 07:37 AM
Yeah, Karl!! I have the Interstate calender behind my desk here at work. Can't for the life of me figure out why I didn't get MM to sign it so I would have the collector's edition, too!!
RED NINJAS RULE!!
redelk
Please... speak to the hand.
posted August 06, 2002 07:51 AM
kawachan, do you have the signed cap and shirt too?
-Ernest Hemingway
posted August 06, 2002 08:50 AM
A CAP??????
what the hell??? I am missing a cap????
Prolly should have hit MM up for a cap when I bought that MCR2 from him. shit! opportunity lost...
0.24617004394531 seconds processing time
