BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Warped Rotors NEW TOPIC NEW POLL POST REPLY
bluemoss
posted April 25, 2008 08:19 AM
Warped Rotors
What conditions indicate the rotors are warp?
Blue
posted April 25, 2008 11:01 AM
dial indicator will tell the story.
If you have to pump the brakes to get the lever out when braking is a good sign that the rotor(s) are warped (assuming you have a hard lever (no air in system). No amount of pumping is gonna give you a solid lever if there is air.
tshultz
posted April 25, 2008 12:57 PM
When you use the front brakes and it's vibrating really bad. That was the case with my dad's zx-9 replaced the front rotors with new ones and the problem was gone. Both rotors were warped pretty bad.
zx12mark
posted April 26, 2008 04:02 PM
try cleaning both the rotors and the pads with brake cleaner real good.you may have some oil on them.if not you know whats nexts.....good luck.
almost_les
posted April 26, 2008 06:04 PM
if they are warped, i got a set of stockers with 5k on them i'd sell
posted April 26, 2008 06:11 PM
IF they were JUST Vibrating that would be the cure but they are also knocking back the pads which is a "Physical" thing as in bent!
0.41501593589783 seconds processing time
