BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Secondary TB NEW TOPIC NEW POLL POST REPLY
jus1975
posted April 21, 2008 07:58 PM
Secondary TB
Has anyone removed them from there 12. What did you do about the map?
docsninja
Backs and Bikes is what I do..
posted April 22, 2008 11:16 AM
I am wondering the same thing. I have an 05' and they seem to be more like the 14 then the early model 12's. I want to remove mine and get it mapped but was wondering if just the plates are to be removed, or the plates and the shaft that goes through to twist. If this is the case, how and with what should the holes be plugged? thanks in advance.
Docs Cycleworx home of Dr. Ryan Scarsella and SmokinZX14.
  Ignore this member    Click here to visit DocsNinja's homepage.
jus1975
posted April 22, 2008 11:41 PM
I was going to compare the maps from the 02 and 03 models to the 04. It should be ok. I removed them and was going to try it out later. I figured that someone would have tried it by now.
capt10ed
posted April 23, 2008 02:28 AM
I believe someone did remove the STB and reported no difference. I can't see how. If you remove an obstruction from inside the bores it could only help. Second I wwould think the engine would rev quicker..
and 204.5 in the mile.
jus1975
posted April 23, 2008 07:41 AM
I believe it does rev quicker. I just started for a while and it did seem to rev quicker, but I want to make sure its not leaning out.
docsninja
posted April 23, 2008 10:33 AM
So when you removed them, Did you remove the plates off of the shafts, or did you remove the entire thing, plates and shaft out of the secondary butterfly position. doc
zrexpilot
posted April 23, 2008 05:59 PM
I removed the flies on my '04, just the flies, 4 little screws, couldnt tell you if they helped or not, but with them gone and 4dg advance the the thing is real responsive.
posted April 24, 2008 01:17 PM
the 14 guys just take out the plates (the "flies")
jus1975
posted April 24, 2008 11:43 PM
Its was recommended by Brock to tune for the removal of the flies on the 14. I would assume it would be the same on the 12.
0.27506589889526 seconds processing time
