BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Re:CK4513 EBC CLUTCH PLATE KIT 2000 KAWASAKI ZX12R NEW TOPIC NEW POLL POST REPLY
jeremy_kokwk
posted April 16, 2008 07:33 AM
Any one using this clutch kit? is it good?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEBTOX:IT&item=290221413817&_trksid=p3984.cTODAY.m238.lVI
tshultz
posted April 16, 2008 01:01 PM
I have a ebc clutch and springs it works good on the street but not so good at the drag strip.
Hells Dark Lord
living life, and loving it.
posted April 16, 2008 05:45 PM
go with Muzzy......
NOX
PMRA / TMRC Super Street 4022
posted April 16, 2008 07:03 PM
go with Muzzy......
Stock.
But what the hell would I know....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
biggmoinc
posted April 17, 2008 07:15 PM
2000 zx12r with 1270 kit and a clutch that slips when above 9500 rpms, any suggestions. And I believe the muzzy basket is in it already, so do i go with muzzy clutch or stock. I put schnitz heavy springs n slippage stopped for awhile but they got weak after a few months, i dont even drag but occasionally roll on the throttle here n there. Added power but cant get it to the back wheel. also has a 240 tire kit
biggmo@aol.com
krexken
posted April 19, 2008 05:02 PM        Edited By: krexken on 19 Apr 2008 18:08
Your springs aren't getting weak, your steels are toasted and your fibers prbably are also. Your steels may be digging into your hub adding to the problem. If your hub is really notched up from the steels, toss it. An 00 needs a drilled hub like Muzzy sells. The Muzzy kit works well but it's pretty dang easy to drill your own hub and put a flat spot on the puller shaft for extra oil. The transmission shaft the puller shaft is inserted into is pressurized with oil so a small, 1/8" flat spot or so all the wasy down the inserted piece of the puller shaft will help feed the clutch plates. I like the OEM clutch parts like the thickest, 2mm steel and stock fibers. I've yanked out aftermarket steels and fibers becasue most of them suck. One of them had steels so pointy they really dug into the hub and wouldn't let the clutch properly disengage when the lever was pulled in. Aftermarket crap.
posted April 20, 2008 11:13 AM
I hear ya Nox...I like the OEM 2002 set up myself !!!
NOX
posted April 21, 2008 05:33 AM
But how could it work, it does not say Muzzy on it.......?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
biggmoinc
posted April 25, 2008 06:35 PM
if i have a muzzy basket and hub in a 2000 can i use say a 02 or 03 oem clutch, i see they are slightly different than the 00
biggmo@aol.com
NOX
posted April 25, 2008 06:54 PM
Should be able to.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.22715592384338 seconds processing time
