BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Finetuning of Powercomm. NEW TOPIC NEW POLL POST REPLY
Fantomet
zx12r2000
posted April 15, 2008 04:15 AM
Those of you who have raceexaust and powercomm - Did you notice a big difference after getting the powercomm finetuned on bench?
Have any of you tried other maps than Powercomm.com recoments for your exaust/filter?
My big problem is there are no real experts on finetuning here where i live!
KNfilter
Full Muzzy
Pc3
180rwhp
Step aside folks - comin through!!
NOX
PMRA / TMRC Super Street 4022
posted April 15, 2008 04:53 AM
Whats a filter?
I ran Brocks Map when the track was good, and a 0 map when bad........
Now I run a modded brocks map, that vp said to use, it works good.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Fantomet
zx12r2000
posted April 15, 2008 05:18 AM
Filter - Airfilter.
Whats a Brocksmap? Where can i find it?
Does a 0 map mean stock exaust/filter?
By modded you mean modified?
(Im new to the Powercommgame, and allso im from norway so my english is kind of easy...
KNfilter
Full Muzzy
Pc3
180rwhp
thekaz
spell chequer is bustimicated
posted April 15, 2008 08:37 AM
The best thing to do is search the PowerCommander web site for a map that is close to your pipe,air filter and other mods. They have lots of maps there so if you find one that is close then use that as your "starting" point.
Fine tuning then really takes some real world setup .......
posted April 15, 2008 01:03 PM
I wrote something about doing this for Starters! By Marking the Throttle Grip with a "V" Notch and then the housing aith 0% (Slack taken out) and 100% then 50% 25% 12.5% (Close enough to 10% then 6% When you are riding and feel a problem all you need to do is look down and see the thottle Position and rpm and "Remember" it and change the mapping at Home! A little at a time and you will have a SUper map for your bike!
thekaz
posted April 15, 2008 01:29 PM
I COMPLETELY AGREE
A map that has been created via actually riding the bike will always be better......in the days of old this is how we used to fine tune carbs
sfoda
posted April 16, 2008 03:05 AM
How about taking it to an experienced dyno operator with a the Tune link software and an electric brake on the dyno. They are listed on the website, but it will be more difficult to see if he is experienced.
This is the only way to make fine adjustments under load for your exact combination. I know a guy in Daytona that does custom maps for $225 - $250.
If you drive far for a dyno, think about altitude, temperature, and humidity.
posted April 16, 2008 03:34 AM
The problem even with a load Dyno and as careful as they can, they cannot map for every possible Throttle and load Conditions that YOU WIll experience!
Kaz, I NEVER Thought I would see the day that I would Curse a set of Carbs and WISH i had FI on a motorcycle! Now a lot of people cannot tune carbs because they do not know the overlap points and what % of effect they all have on each other! WHen I tuned the carbs it would even get down to the Height of the Needle Jet Choke
87gtNOS
posted April 16, 2008 04:47 AM
I tune on the street. Last summer (ZX14) I started out with a muzzy slipon map....dyno'd it, 171 rwhp SAE, and the dyno guy said he'd leave it be...but I made many changes over the summer. Drive ability improved greatly.
I carried my laptop in my backpack to work with me almost everyday. At lunch time, I'd go cruise around, and make slight map changes. You CAN tell if you made a good or bad change. I also learned where my THROTTLE position was on the grip. MOST important positions are the lower positions, 2, 5, 10, 20, 40%. This is where you drive the bike, and surprisingly, 2 and 5% throttle positions are used MOST of the time!
I am currently going through the process again with full exhaust. I am trying various pre-made maps, looking for the best drive ability. That is the map I will take to the dyno. It is still cold outside in the mornings, like 34F!! Riding at 45F, the bike runs good, but still rich, tailpipe is black!
Once a dyno map is made, I am sure I will be tweaking it!
01 ZX12R
almost_les
posted April 17, 2008 05:48 PM
the powercommander.com map i used sucked ass, made the bike run like it had brain damage. i'm at too high of an altitude for it to work right. i went to a local shop with a dynojet 250i (has a load cell and an o2 sensor on it) and gained 5hp up top, and 8hp in the mids. thats how far off the map was! you might as well try a web map to see if it works, but if its acting up, head to the nearest shop to get it tuned.
0.24369812011719 seconds processing time
