BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is all years zx12r fuel pump the same? NEW TOPIC NEW POLL POST REPLY
jeremy_kokwk
posted April 12, 2008 08:45 PM
Any bros knows the answer?
posted April 13, 2008 04:15 AM
the a pump is different than the b pump
jeremy_kokwk
posted April 14, 2008 04:08 AM
oh is it
thx thx
posted April 14, 2008 04:15 AM
oh is it
thx thx
The A Pump is designed for return Fuel and the B Pump does not have this return!
jeremy_kokwk
posted April 16, 2008 07:30 AM
So if i used a B pump on A model? will it affect? coz i bidded for one in ebay and only was told that a model and b model pump is different. Going to get a strike in ebay soon.
posted April 16, 2008 04:03 PM
Simple! It will Most likely Bolt Up but Where are you going to run the Return line on the left side of the FI that went to the Old Pump?
ninja12
posted April 17, 2008 08:21 AM
IF you have the pump , Block off the return and let us know.
IF you don't have a pump muzzy sells a walbro pump upgrade for the A model.
Y2k (Jim) has a couple walbro numbers if you don't want to go thru muzzy.
I think the muzzy kit is around $200 but the pump is around $120.
posted April 17, 2008 01:03 PM
The Return SIde Controls the Fuel Pressure in the A-1 with a Small Valve in the Return tube! If you block off the return line the pressure Shoots straight up and the Mapping will not work. If you add a Return tube then you will still need the Valve to control pressure!
Working with my Bypass Flow through fuel pressure regulators on my LSR Bike taught me a LOT about controlling this Pressure and it is no SImple thing to do!
0.2493360042572 seconds processing time
