BIKELAND > FORUMS > ZX12R ZONE.com > Thread: R & D MOTORSPORTS dose FANTASTIC WORK NEW TOPIC NEW POLL POST REPLY
zx12mark
posted April 11, 2008 08:16 PM
i waited to post and now i must tell you guys my transmission is awsum.
mark at r&d was able to referb almost every part that had wear which was`nt many.i had never split engine case`s before but if you can swap valve shims on a zx12 you can get those transmission shafts out to send to mark if yours are fucked.i replaced my timing chain and thermostat while i was at it.i also adjusted the valves and sync the throttle bodies. i guess i had about 45 hours into the whole job.r&d`s bill was around 750.00.i had a ron ayers bill of parts for around 200.00 unrelated to r&d`s work.i have been fucked to tears by stealer-ships in my life.
NOT ONE OF THOSE MOTHERFUCKERS WOULD DO THIS JOB AS GOOD AS I DID IT.a stealer-ship would charge at least 1500.00 for labor alone.so the way i look at it is i got the job done free and got payed 500.00 for doing the work.mark at r&d is a true wizard.please give him your business if your transmission is sick.
0.25606608390808 seconds processing time
