BIKELAND > FORUMS > ZX12R ZONE.com > Thread: PIT BULL ADJUSTMENT.. NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted March 19, 2008 12:22 PM
is there a problem with adjusting the chain while the bike is on a rear stand,, or with it be too tight once sitting on the bike off the stand? how do you guys do it? while the bike is on the side stand? etc.. thanx
posted March 19, 2008 01:11 PM
i had to adjust the chain after taking it off the stand, maybe only because im extended? not sure....
NOX
PMRA / TMRC Super Street 4022
posted March 19, 2008 03:14 PM
I have to be sitting on the bike, but thats cause I am at 68 inches........, it gains a ton of slack when the bike squats..........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
twista
posted March 19, 2008 03:29 PM
i just trying to find out proper technique for chain tightening,, and if its beneficial to have it on a rear stand or not!
posted March 19, 2008 04:22 PM
going to have to try out the sit on way.... i would hate to see it if i hadnt adjusted it after i took it off the stand...
check out the sag in the chain. the pic they used on my plaque was from the first of the season....
Nox, you dont have this much sag even sitting at more WB right?
NOX
posted March 19, 2008 10:08 PM
I would say close........
I know my chain goes crazy.......
look at some of my vids.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
MAXIMUS
posted March 20, 2008 05:39 AM
Have someone sit on the bike that is near your weight. Then you get down and adjust it.
posted March 20, 2008 07:53 AM        Edited By: dougmeyer on 20 Mar 2008 08:53
Sit on it. And, if it's stretched (the bike I mean), bounce on it to make sure it doesn't get tighter when it squats. Hard to have it too loose.
twista
posted March 20, 2008 12:28 PM
Bone stock except pipe and bmcs,, different gearing 17/45 so i guess the wheel base is a tiny bit longer than stock? just have someone sit on it,, or can i just do it with noone on it being its stock configured? thanx
posted March 20, 2008 02:09 PM
With no weight on the bike you need to be able to put a ruller along side the chain in the meddle between the 2 sprockets and raise the chain 1 inch. That is 1 inch from either the top or bottom of the chain using the SAME part to measure. As the suspension goes through its arc, the chain will get a little tighter until the Front sprocket center, the Swingarm Bolt and rear Axle are all in 1 line that is straight after that point the chain starts to get loose again. As someone here said, the longer the arm the more slack you need
0.23859190940857 seconds processing time
