BIKELAND > FORUMS > ZX12R ZONE.com > Thread: a braking problem NEW TOPIC NEW POLL POST REPLY
bignblue
posted March 18, 2008 10:12 PM        Edited By: bignblue on 18 Mar 2008 23:14
a braking problem
i lost about 50% braking power after getting generous with cleaning fluid and WD40 which i suspect got into the calipers/pads,
i dint get much response on the org
http://www.zx-12r.org/phpBB2/viewtopic.php?t=52062&sid=d7de84974c463aa67ce8723d6a626391
i have a 05 model with 6000 road miles on it so i dont suspect the pads,
i was told to use break cleaner on the calipers and pads
i can get the pads out and clean them, but undoing the calipers may be a prob for me if it simple enuff i can do it if i have proper instruction
some help here guys
maximus
posted March 19, 2008 06:25 AM
One word man, contamination once those pads soak up that WD40 they are done, you will not be able to get it off the pad, some brake clean for the rotors and new pads you will be fine. Removing the calipers is not difficult at all, its pretty easy. I do not have step by step instructions.
maximus
posted March 19, 2008 06:26 AM
What were you trying to clean with WD40?
posted March 19, 2008 07:40 AM
2 bolts hold on the calipers. its pretty easy. dont use oil on brakes!
bignblue
posted March 21, 2008 06:25 AM        Edited By: bignblue on 21 Mar 2008 07:27
thanks for the feedback maximus
i has just a few dots of rust on the disc, which i hoped would break loose with WD40, i managed to get rid of 80% of the rust and later used wd40 to clean the calipers as well...very bad idea
time to order new pads i guess....should i go with EBC?
i tried undoin the bolts that hold the caliper but they wouldnt budge!!, i think ill have to take it to a mechanic to undo it with a impact gun
there goes servicin cost
posted March 21, 2008 11:29 AM
which bolts are you trying to remove? not the ones which clamp the 2 halves on the caliper together i hope...
the rear doesn't have any bolts and i've never heard of the fronts resisting removal.
maximus
posted March 21, 2008 12:34 PM
I always used stock parts, but EBC brakes are very good in performance from what I understand.
bignblue
posted March 22, 2008 08:39 PM
the 2 main bolts that connect the calipers to the forks...
Hells Dark Lord
living life, and loving it.
posted March 27, 2008 10:11 PM
EBC HH pads are a good choice for street riding......nothing wrong with stock pads if you just ride the bike normally....if you ride twisties hard you might get some fade with stock pads.....Personally I like the Braking CM55 pads.....I use those on my ZX10R on and off the track....
0.23799395561218 seconds processing time
