BIKELAND > FORUMS > ZX12R ZONE.com > Thread: manual setting for PC 3 NEW TOPIC NEW POLL POST REPLY
johnnnyboy
08 Concours 14
posted March 08, 2008 03:39 PM
well no doubt about it I cant up load a file to my PC3 some thing s wrong so does any one no what I could manually adjust it to for best results with my set up ive got a 2000 with k&N s with a yoshimura bolt on. right now I have it Low +2 mid -2 high -2 I was thinking a little rich for low and lean for mid to high.
any one have any sugestions ? thanks
supra5677
posted March 08, 2008 05:42 PM
you don't need a pc3 with just a bolt on pipe.... just unplug it....
supra
better yet send your ecu to RR
johnnnyboy
08 Concours 14
posted March 08, 2008 06:18 PM
so theres no advantage at all with only the bolt on and k&n
using the PC
supra5677
posted March 08, 2008 07:27 PM
by bolt on you mean" slip on " right? stock head pipe?
johnnnyboy
08 Concours 14
posted March 08, 2008 07:53 PM
well they call this one bolt on but yeah slip on would be the same and yes it does have a stock head pipe but every thing has been removed from the inside of it
supra5677
posted March 08, 2008 11:05 PM
ask some other members.. but I would just unplug it.
zx12mark
posted March 09, 2008 09:48 AM
if you can get a good map in the pc3 it will make more power and clear up flat spots.
have you tried having the engine running when you load a map.are you using the right port on your computer to talk to the p.c.3.
supra5677
posted March 09, 2008 07:35 PM
maybe rr can cross reference the pc3 map directly into the ecu...
0.23952913284302 seconds processing time
