BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Front Rotor Bolt Broken - Need Advice NEW TOPIC NEW POLL POST REPLY
riteristrob
posted February 12, 2008 09:47 PM
When taking off a front rotor on my zx12r I stripped the head of the bolt. I drilled it out for a #3 screw extractor and broke the screw extractor off in the bolt. I used a tungsten carbide cutter on a dremel tool and was able to cut away the piece of extractor.
Decided to go to a #4 screw extractor. The drill size is 1/4 inch, which is very close to the size of the bolt minus the threads. Unfortunately, my hole wasn't straight and I caught the threads in the wheel with the 1/4 inch drill bit.
So my questions.........
Should I take the wheel to a machine shop and have a heli coil insert put in, or buy a new wheel?
Does anyone have experience with a heli coil in a wheel? Cost? Any down sides?
Does anyone have a straight front wheel for sale for an 02 ZX12R?
shane661
posted February 13, 2008 03:23 AM        Edited By: shane661 on 13 Feb 2008 03:24
For one rotor bolt I don't think a hel-coil will be a problem. They aren't torqued very high, and you will be using loctite anyway. I do drag and lsr racing as a hobby, and a heli-coil would be sufficient for me. Just my .02.
woppî
posted February 13, 2008 03:31 AM
yes, i think so to !!
woppi
riteristrob
posted February 13, 2008 05:45 AM
Thanks fellas. I guess I'll call a machine shop today.
btw I forgot to mention I need a rotor bolt too.
I'll send $5 for a clean undamaged rotor bolt.
posted February 13, 2008 06:51 AM
the wheel may need to be balanced afterwards, but you probly wont notice anything
posted February 13, 2008 09:00 AM
Next time heat the bolts up with a small torch, heat gun...If not then loosenbolt a little then tighten then loosen a little more and keep doing it that way until its out...Takes time that way but at least you wont break or strip the bolts
riteristrob
posted February 13, 2008 11:39 AM
Good advice CR thanks!
stuart racing
N.H.R.A . Dragracing.
posted February 13, 2008 12:56 PM
I have a blue 02 wheel if ya need one.....
chuck762
posted February 14, 2008 04:50 AM
Get a time-sert installed. Much better than a helicoil.
zx12mark
posted February 14, 2008 01:34 PM
you will be fine with a new insert.
riteristrob
posted February 15, 2008 09:14 AM
Stuart Racing - I'll let you know in a few days about the blue 02 wheel. Just in case I do need it, how much are you asking?
I found a local shop that said they could burn out the bolt with an EDM machine. I love science. He said if the threads in the wheel were damaged then I could go with an insert with no problem. We'll see.
riteristrob
posted February 19, 2008 07:07 AM
I had a local shop use an EDM machine to burn out the old bolt. The threads in the bolt hole were slightly buggered at the very top, but the bolt still grabs 90% of good solid threads.
Now to finish my polishing project.
0.25469517707825 seconds processing time
