BIKELAND > FORUMS > ZX12R ZONE.com > Thread: swing arm affaire NEW TOPIC NEW POLL POST REPLY
GOZR
GOZR
posted July 20, 2002 11:34 PM        Edited By: GOZR on 22 Jul 2002 09:32
Swing arm affaire
Anyone has the specifications of a swingarm out of a zx7rr 1996 Vs The zx12's swingarm?
can swap it?
The zx12 at lemans's race was runing with a 1996 zx7rr swingarm ( shorter )
-G
GG
posted July 21, 2002 04:59 AM
Swingarm
I was ondering the same thing!
posted July 21, 2002 06:10 AM
I just measured my ZX12 swingarm
-25mm axle
-its 10 1/8 inches wide (through the frame area)
-its 25 1/2 inches long overall.
If the ZX7 shock mounting area is slightly offset, then your in business.
GG
posted July 21, 2002 06:53 AM
How much offset? Can you do it with spacers or shims if necesasry?
Dino
posted July 21, 2002 05:17 PM
Does this mean the RAM SSSWINGARM will work on the 12??????
uh oh
frEEK
posted July 21, 2002 05:44 PM
ooooooo.....now THAT's interesting!
posted July 21, 2002 05:47 PM
I saw one today, and it looked very similar to the 12.
All I can say without actually measuring the ZX7s arm is that it is off set like the ZX12. You may be able to space it out with shims. Didnt bother to look at the pivot axle that runs through the frame.
Certainly you can find a used ZX7 arm for ~$150 or less.
posted July 21, 2002 08:20 PM
Wow! Interesting! I'll definately have to check this out!
Zhooligan
Post Whore Extraordinaire!
posted July 21, 2002 09:50 PM
If a 7's swingarm works, I can see some more changes coming to the 12!!!
future; -- Youth is forever.
GOZR
GOZR
posted July 21, 2002 11:05 PM        Edited By: GOZR on 22 Jul 2002 00:09
Look at this one
BTW! they monted it with 180 at the rear
-G
frEEK
posted July 21, 2002 11:37 PM
arg, my french isnt good enough to make out more than 1 in 5 sentences am likin those rotors tho.
GOZR
GOZR
posted July 22, 2002 12:08 AM        Edited By: GOZR on 22 Jul 2002 10:40
No probs
But i'm trying to find more infos about it..
It seams to me also that they balanced the bike differently ( higher rear )
I just know that the 12 above is the best made 12 for racing... so i realy think that we can learn some good tips about it
With the stock swingarm the bike is 1440 mm and with the zx7rr swingarm the bike goes to 1410 mm...
The alternator is from zx9
Added an radiator from a kx kawasaki and touk off the fan..
-G
posted July 22, 2002 12:15 PM
I know that Yosh removed two *inches* from a Bus frame when they built their (highly unsucessful) F USA Bus. How many mm is 2 inches?
posted July 22, 2002 03:20 PM
I guess shorting the swingarm 2" would make the bike a bear to ride on long straights! The wheelbase stock is ~56", I could imagine trying to keep it down with only 54"! Im sure it would be usefull on tight, technical courses or roads.
ZHooligan
posted July 22, 2002 04:09 PM
25.4 mm to an inch.
The real problem with the busa a a formula extreme bike was that it was underpowered!
GOZR
GOZR
posted July 22, 2002 05:16 PM        Edited By: GOZR on 22 Jul 2002 18:21
They talk about how they were afraid for the 12 to be instable, but after many test the bike was very stable... of course with a want to wheelie mood but they said that it was a perfect setup....
-G
GOZR
GOZR
posted July 22, 2002 05:29 PM        Edited By: GOZR on 22 Jul 2002 18:31
anderstand something is that this 12 did the 24 hours race lemans but fault of a gas leek to the rear tire the bike went down and couldn't get back into the race again but the 12 was in 3 position and was getting closer and closer to the first ones...
Passing how many gsxr 1000's and many many others...
I realy think that they did something ameasing..
I have a immense respect for this team..
-G
frEEK
posted July 22, 2002 11:13 PM
which year was this gozr? i remember the bike was doing very well 1 or 2 years ago & also went out part way thru (past half way i think), but i think it was due to mechanical or electrical problem.
magzx12r
posted July 23, 2002 01:10 PM
Shortening the swingarm would take away some of the weight on the front, so it looks like they raised the rear ride height to counteract this. Can you raise the rear ride height with the stock shock?
Mark
'03 ZX-12R
'12 1199S
Zhooligan
posted July 23, 2002 02:53 PM
You would have to shim the stock shock as it does not does not include a ride ht. adjustment option. Now my Ohlins does!!
0.2718780040741 seconds processing time
