BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Is this normal? (PIC) NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted December 18, 2007 08:10 AM        Edited By: twista on 18 Dec 2007 08:11
i bought this EK DVX2 Chain and noticed the one link isnt like the others.. is this normal there is no master link,, im thinking this is the factory master when produced,, am i right or should i be concerned? it is the link in the middle on the right.. thanx for the input..
it looks dimpled and has a little corrosion.....
posted December 18, 2007 10:59 AM
110% normal.
That is a hand riveted "master link", and a damn fine looking job at that.
twista
posted December 18, 2007 11:31 AM
Cool,, what is better this type or a master link or does it matter,, should this be of concern,, the chain is MINT said it was new,, got a killer deal on it.. just want to make sure everything is safe,, since it was a USED PRIVATE PARTY SALE... $80 bucks for the chain and a new 14/49 sprocket set!
thekaz
spell chequer is bustimicated
posted December 18, 2007 11:35 AM
rivted chains are better and now a days the rivitors are cheap
posted December 18, 2007 11:48 AM
look at it this way, its never going to come apart like a master link can (which is usually only from improper assembly tho)
you can safety wire a regular master link, but the rivit type, when done right, will never fall apart(any faster than the rest of the chain)
TRNorBRN6001
posted December 18, 2007 12:46 PM
.......................or did someone rivet two pieces of chain together to make one length of the right number. So you will just be running two rivet sections. They might frown upon it at an LSR event, but just slip they tech guy a twenty and he'll shoot ya right through.
I do not think its that big a deal especially for $80.
TFA 200MPH CLUB MEMBER!
twista
posted December 18, 2007 01:16 PM
would they have lengths to cut EKDVX2,, this is a 116 link which is stock???
posted December 18, 2007 02:14 PM
master link, 2 types
1. clip style, sort of re-useable (I would never reuse a clip, never)
2. riveted, not reuseable
Both hold fine if installed correctly. Both have to have the outer plate pressed on.
Looks like some one bought a length of EK DVX2 and used the rivet type of master link to put the chain on. No faz mal, it'll work fine.
Just check that the pins on either side of the "rivet style master link" rotate smoothly. If they do, RUN IT!
IMHO
twista
posted December 18, 2007 02:46 PM
10-4 , say no more!
shiphteey
posted December 18, 2007 04:17 PM
Did you say 14/49?
WTF!?!?
A.
Gemini Motorcycles
twista
posted December 18, 2007 04:58 PM
good eye,, i didnt even notice that,,, it was 17/49 my bad!
shiphteey
posted December 18, 2007 06:59 PM
Makes more sense. I'll be trying 16/46 soon. Shortest gearing I've tried so far is 16/44. 17/49 is a bit steeper for sure. 3rd gear throttle wheelies?
A.
Gemini Motorcycles
twista
posted December 18, 2007 07:19 PM
yea after running the 17/46 for a while now,, ive come to realize that its just to steep for me,,i frequently find myself reaching for a 7th gear thats not there,, so i went to a gear ratio website,, and decided that i want to go with 2/3rds of the low end that i have now which means going to 17/45 it will give me 1/3 of my top end back so that is from stock (2.56)
to 17/46 (2.71) to where i want to be 17/45 (2.65) ration,, i think i will be pleased with that setup and still be able to have the wheel come up at will like the animal that it is,, the new billet setup is tits! thanx for all the help again! Vic
that 17/45 should work with a stock linked chain correct (116) ??
0.25419807434082 seconds processing time
