BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cam ??? NEW TOPIC NEW POLL POST REPLY
kingkwik
9.36@ 149.23
posted December 15, 2007 08:13 AM
cam ???
Hey peoples!!
Whats the short and skinny on the cam mod for my 2004 zx12?
Is it just a swap, replace my exhaust for another intake or what? Or do I have to replace the exhaust cam with a web intake??? Do I have to do anything in conjunction with this mod to get any benefit??
What aboiut head gasket replacement? And if so wheres the best place to buy?
thanks a bunch.
If it has wheels or tits its bound to be trouble!!
supra5677
posted December 16, 2007 08:02 PM
send me a pm..
posted December 16, 2007 11:16 PM
oh just post it for everyone, im curious too, i havent really looked into this much yet.... something must be done with the sensor for it to work...
posted December 17, 2007 04:45 AM
Hey peoples!!
thanks a bunch.
lotsa possibilities, you need to be more specific about yr set up and application.
posted December 17, 2007 04:09 PM
Ill try to be more specific, i might be thinking the same way, but if not at least its promoting discussion.:P
what does it take to run 2 intake cams? (one on the EX as well)
another option idea:
what does it take to run an intake cam on the exhaust side and an exhaust cam on the intake side? (the only way this would make any sense would be if you sent the EX cam to be welded up and reground (to match or better yet, "beat" the IN cam specs)
krexken
posted December 17, 2007 05:29 PM
You only need to drill the pin hole so the thingy can be bolted to the end. Pretty simple. It will be properly indexed also. Somebody makes an adapter to use a later model cam easily since the thingy is indexed differently, I believe. Not sure anybody has any good info on how much hp cams are worth in a certain engine. The 12 comes with relatively large cams already so gains aren´t going to be huge. I´ve installed two intake cams in some engines and used a weldup on the intake and intake on the exhaust on others buy no dyno results to back anything up. Basically, if money isn´t much of an object, I´d use bigger cams. I´ve seen weldups with 10k on them and still look like new.
hyper12r
posted December 19, 2007 12:47 PM
just wondering..which is bigger? muzzys or web?
posted December 19, 2007 10:32 PM
Web has a variety of grinds, "bigger" and "smaller".
hyper12r
posted December 20, 2007 12:04 AM
the ones on ape web?
383"/.369" 276°/280°
http://zxzone.com/cams.html
posted December 20, 2007 02:23 AM
you are right!
Web only offers 1 cam set for the 12 now. They used to have a good variety??
hyper12r
posted December 20, 2007 04:44 AM
they recommend that for stock bore??
but which is 'bigger' web or muzzys??
thanks
posted December 20, 2007 05:50 AM
Muzzy, duration int=245 @ .050. lift = .402,
Muzzy, duration exh=238 @ .050. lift = .390,
Web set, duration int=253 @ .050 lift = .383, Web grind #227
Web set duration exh=252 @ .050 lift = .369, Web grind #549
Muzzy = higher lift
Web = longer duration
hyper12r
posted December 20, 2007 08:07 AM
thanks entropy....
supra5677
posted December 20, 2007 10:06 AM
I have the web cam intake only.. Pulls hard after 5000..
capt10ed
posted December 20, 2007 01:46 PM
Which one works better in a 1270/1287?
and 204.5 in the mile.
0.22222208976746 seconds processing time
