BIKELAND > FORUMS > ZX12R ZONE.com > Thread: valve adj.. NEW TOPIC NEW POLL POST REPLY
kaw12
posted December 12, 2007 03:06 PM
valve adj..
is it hard to adjust the valves? i hear a little ticking and maybe they need to be adjusted. 13000 miles.. only serviced once after breakin.
krexken
posted December 12, 2007 05:25 PM
It´s kind of a pain just to check them. If one needs to be changed, it´s a real pain. Nothing that can´t be accomplished though, especially with the manual beside you. Just don´t get in a hurry.
ninja12
posted December 13, 2007 10:59 AM
vavles wear tight not loose, you will get a miss not a tick.
most of my ticking comes from exhaust leaks.
twista
" Get up, and Stay up ! "
posted December 13, 2007 12:06 PM
if its cold out and you hear it then it goes away,, it could be the oil??
lgm118icbm
posted December 13, 2007 12:12 PM
What about your cam chain tensioner?
Costa Mesa, Ca
03 ZX-12R
03 Z-1000SC
04 ZX-6R
98 Concours
tuusinii
posted December 14, 2007 12:02 AM
Checking valves isin't really that bad. Maybe couple of hours and one hour more if You have to change the clearance. And if Your doing other maintenance You allready have the plastics of anyway. The horror stories about removing engine and all that stuff aren't true. I find it even easier than X11 because You don't have to remove airbox and carbs and all the that stuff. It really isin't "pain in the ass".
0.22805309295654 seconds processing time
