BIKELAND > FORUMS > ZX12R ZONE.com > Thread: **Ping Redelk** NEW TOPIC NEW POLL POST REPLY
Otis
Captain Kickstand
posted July 11, 2002 08:11 AM
**Ping Redelk**
Hi Sherman, was interested in your thoughts on how your rear suspension improved after recharging the nitrogen. I went back to re-read the posts about it but didn't find a follow up to the work. Is it much better?
I have 17,500 on my 12 now and the rear is starting to feel a little "bouncy" maybe that's nit the right word I'm looking for but this morning I remembered your posts about the nitrogen and I'm thinkin' maybe I'm due.
Can you please tell me what's involved with removing the chamber to take it in to have it charged? Also, can you explain a bit more about drilling the hole to get the cap off with a screwdriver? Thanks for you help.
It's a free country brother
Otis
Captain Kickstand
posted July 11, 2002 08:16 AM
OK I answered by own question about the canister, you have to remove the whole shock eh? Now the question is how do support the rear of the bike without loading the suspension. How did you support the bike red? Obviously the rear stand I have won't work.
redelk
Please... speak to the hand.
posted July 11, 2002 10:17 AM        Edited By: redelk on 11 Jul 2002 11:20
You asked!
Can we say... "jack stands"?
(note shock sitting in the tail section)
Since I was changing the springs out in my forks at the same time, I had very few options in my humble lil' garage. Notice I used FOUR jackstands. I'm sure there are a varity of other and easier methods, but this is what worked for me.
As for the "improvement" after getting it recharged? Can we say... "OH MY GAWD (it's in the details)!" Though the new (and heavier) forks springs made telling the differnce a tad tougher, it was unquestionable that recharging the shock made an almost scary and huge difference.
I think the OEM spec is around 140 PSI. I had less then 60 PSI. After filling out a RaceTech survey, I ended up putting 200 psi in. Like I said, it's kinda erie on how the bike has change.
AGAIN, an IMPORTANT REMINDER...
Make sure that who ever is going to recharge your shock has a "nitrogen needle" because the standard "tire valve" attachment will NOT work. They can get the needle from Motion Pro for less the $30.
-Ernest Hemingway
Otis
Captain Kickstand
posted July 11, 2002 10:36 AM
Jack stands, good idea my friend, I have four of them myself so that is what I shall use. I will call the dealership today to ask about the needle to make sure they can do it, if not I'll call a couple others to see. Now I weigh 220 should I also have em' fill it to 200lbs? Also, any tips on getting the shock out or is it as straightforward as it seems?
redelk
posted July 11, 2002 12:50 PM
Shocking suggestions
I'd suggest you go to RaceTech's site and fill out the rider survey.
I'd also suggest that you consider doing something with the forks as well, if you haven't already.
Being the poorest guy on this forum, I couldn't afford to send mine off, but for about $100, I got the heavier springs and a bottle of 5 wt. fork oil. The OEM spec is 10 wt., but RaceTech's suggested the lighter oil WHEN using THEIR valving (which I am not... again, $$$).
Changing the springs and oil in the forks is actually more of a hassle then removing rear shock. Your correct, the shock is fairly easy to unbolt. For me, I found it easier to just remove the tire. I guess you could still do it with the tire on, but why hassle with it? Kinda like leaving the radiator on while putting a new header on.
I just removed the bottom bolt and unbolted the top bracket from the frame. The bracket bolt is located under the tank and also has a cotter pin (under the rubber cap). I just didn't want to hassle with trying to unbolt the shock from the top bracket. One bolt on bottome, one on top and out it comes.
-Ernest Hemingway
Otis
Captain Kickstand
posted July 12, 2002 03:05 AM
Thanks for the info Red. I still have the info you e-mailed me about the forks but for some reason I get the whillies thinking about tearing into them.
kawachan
posted July 12, 2002 07:15 AM
Man, Red!! That is a classic pic of a "12 on blocks"!!
RED NINJAS RULE!!
Otis
Captain Kickstand
posted July 12, 2002 07:17 AM
You know Kawa, Red does nothing half assed. lol
0.25388717651367 seconds processing time
