BIKELAND > FORUMS > ZX12R ZONE.com > Thread: oil pan? NEW TOPIC NEW POLL POST REPLY
kaw12
posted October 08, 2007 02:08 PM
oil pan?
anyone have a good fix on dripping oil plug? oil pan got stripped from overtightening.
posted October 08, 2007 07:43 PM
take the pan off and put in a heli coil
aliveagain
posted October 09, 2007 02:38 AM
I believe there was someone on the site,maybe MadMike, who relocated the plug to the backside of the pan.Just something to think about.
kaw12
posted October 09, 2007 01:09 PM
thanks guys, quick fix. its was a bad bolt, thank you.
posted October 09, 2007 09:23 PM
thats not a bad idea anyway! im allways worried about tearing that out.....
kaw12
posted October 15, 2007 02:23 PM
well it ended up being the pan walls, so i took all the fairings off, radiator and headers and dropped the oil pan. got a 1/2 inch drill bit went to work tapped the hole with a 1/2 tap and installed a 1/2 single oversized bolt, problem solved. now it looks like the valve cover gasket is leaking. anyone ever changed this with the motor installed?
posted October 15, 2007 02:40 PM
changing the valve cover gasket with the motor installed is no big deal, pretty easy to do once the plastic, throttle cables, overflow bottle, and various wires are outa the way.
Go for it
NOX
PMRA / TMRC Super Street 4022
posted October 15, 2007 03:34 PM
Heli Coil
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
0.36466407775879 seconds processing time
