BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Kawasaki releases all-new ZX-10R for 2008 NEW TOPIC NEW POLL POST REPLY
staff
posted September 11, 2007 03:16 PM        Edited By: Staff on 14 Sep 2007 10:08
The rumors are true! Details are few and far between - note all the "TBD"s in the spec sheet. Controversial styling cues? Time will tell... Note the mirror mounted turnsignals and the redesigned brake calipers. Yes, it's the real thing.
See below for hi-res photos and specs...
A QUICK LOOK AT KAWASAKI'S NEW 2008 NINJA® ZX™-10R
Factory Superbike Talent in a Street Savvy Performer
For the 2008 NINJA® ZX™-10R, Kawasaki engineers aimed for an ideal superbike with engine and chassis performance capable of satisfying professional racers, combined with top-notch streetbike qualities for mainstream riders. It's a delicate balance, but these aren't your average engineers. They've been directly involved in the development of every 600 and 1000cc supersport machine since the 2003 Ninja ZX-6R, plus Kawasaki's factory Superbike racing efforts, so they have the know-how to deliver the goods.
The result is an exceptionally communicative machine that provides the clean two-way rider and machine dialog demanded by professional racers. Placing the ZX-10R in the racing crucible and applying lessons from that unforgiving environment resulted in an ideal balance to satisfy the most demanding of riders.
Kawasaki engineers relied on the assistance of a professional Superbike rider to push the new ZX-10R's engine and frame components to the limits in actual competition. Parts that met with the racer's approval were then tried on the production test bike, tweaked, retested on the race bike and adjusted again. This process was repeated throughout the development cycle for the all-new 2008 Ninja ZX-10R.
2008 Kawasaki Ninja® ZX™-10R Specifications
Engine:
Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement: 998cc
Bore x stroke: 76.0 x 55.0mm
Maximum torque: TBD
Compression ratio: 12.7:1
Fuel injection: DFI with 43mm Keihin throttle bodies with oval sub-throttles, two injectors per cylinder
Ignition: TBD
Transmission: TBD
Final drive: TBD
Rake / trail: TBD
Front tire: 120/70 ZR17
Rear tire: 190/55 ZR17
Wheelbase: TBD
Front suspension / wheel travel: 43mm inverted fork with DLC coating, adjustable rebound and compression damping, spring preload adjustability and top-out springs / TBD
Rear suspension / wheel travel: Bottom-Link Uni-Trak® with top-out spring, stepless, dual-range (high/low-speed) compression damping, stepless rebound damping, fully adjustable spring preload / TBD
Front brakes: Dual semi-floating 310 mm petal discs with dual four-piston radial-mount calipers
Rear brakes: Single 220mm petal disc with single-piston aluminum caliper
Overall length: TBD
Overall width: TBD
Overall height: TBD
Seat height: TBD
Dry weight: TBD
Fuel capacity: TBD
Color choices: TBD
MSRP standard / Special Edition: TBD / TBD
Warranty: TBD
*Specifications are subject to change.
Source: Bikeland.org & Kawasaki Motors Corp., U.S.A.
NinjaNick
'08 ZX14 (Blue)
Wow....NICE! That passenger seat keeps getting smaller and smaller..lol
They shouldnt even come with one!!!!! lol
jeff martin
Pro (closed)
jamming
NICE ! But i wonder if i can use the exhaust can as a funnel for my transmission on my motorhome. Was there any front profile pics !
i play with boats my wife plays with my dingy.
  Ignore this member    Click here to visit jeff martin's homepage.
DB
Actually since we have the new hi-res pics it doesn't look too bad. EXCEPT for those mirrors/turn signals, they are ugly.
Dan
04 ZX10r (Track only)
08 Concours14
DB
TBD - Like over half that info isn't already known by Kawasaki.
Dan
08 Concours14
nhzx10
posted September 11, 2007 03:51 PM
sorry but i dont like it, the mirrors are gawdy with the turn signal mounted down the stem. The pillion seat looks about 8" higher than the drivers...Whats that abortion they call an exhaust?? It looked much better tucked up by the seat, imho...
DB
posted September 11, 2007 03:58 PM
At least the 08 CBR1000 has the turn signals in the mirrors not like this thing. You have to wonder who designs the minor points like this for kawasaki. They should be fired!!
Dan
08 Concours14
andy
posted September 11, 2007 04:01 PM
Those close ups are like porn to me.
posted September 11, 2007 04:02 PM
I can see the Separation between Kawasaki and Suzuki came too late for the Muffler! At least the Kawasaki only has "1" where the Suzzy has "2"! Nice Bike otherwise
posted September 11, 2007 04:07 PM
Nice 10!!!
I want to read about the press release on the 2008 14 !!!...Fish, lets go already post it up!!!
FasterThanStink
posted September 11, 2007 04:18 PM
At least they did away with the under-seat exhaust. From an engineering standpoint under-seat exhausts make no sense. It puts weight high and to the rear of the bike. The weight should be low and as close to the Cg as possible. Also it puts many additional curves in the exhaust path and makes a much longer path for the exhaust to exit. Like the single sided swing arm the under-seat exhausts are headed for the nostalgia heap.
A sweet looking bike.
That's what gets you.
GUNNER
posted September 11, 2007 04:21 PM
JESUS !!!!!!!!!!!!!!!!!! KAWASAKI STEP AWAY FROM THE CRACK PIPE!!!!!!!!!!!!!!!!!!!!!!!!!
GUNNER
posted September 11, 2007 04:22 PM
I just puked in my mouth A LOT!!!!!!!!!!!!!!!!!!!!!!!!!!
BrooklynNYZX12
posted September 11, 2007 04:25 PM
Its definitely hot but I hope they did something with that crazy tall 1st gear that made the last bike invisible in AMA 1000ss Drag Racing.
Orient Express Top Street Bike Winner 8-4-07
FasterThanStink
posted September 11, 2007 04:29 PM
Kawi could give a shit about drag racing this bike. Superbike racing is what this is for.
The 14 is for the straight line crowd.
posted September 11, 2007 05:00 PM
+1
Wasn't built for the drags. Regarding "ugly bike", please understand it wasn't built for posers either :P
This bike is strictly for the race track.
posted September 11, 2007 05:02 PM
Having one exhaust is a huge plus. The first thing a serious rider removes after a bike purchase is the exhaust. Of course my 14 had "two" and due to that design there's a gaping hole on the left side.
Of course the gixxer 1000 is better suited with 2 "cool-looking" aftermarket slip-ons anyway :P
DB
posted September 11, 2007 05:05 PM
+1
Regarding ugly, it wasn't built for posers? Those mirrors and turn signals have nothing to do with posers. They are UGLY!!!!!
Dan
08 Concours14
nightmare
ACP Racing
posted September 11, 2007 05:17 PM
Ok I just got off the phone with Kawasaki! They told me that once they finished the bike, They noticed that there were no turn signals for the front so they had to stick them on the easiest place which is why that would be the first thing to go in my book!
2006 ZX14 Ninja "SWINE FLU"
60ft 1.23
8th Mile 5.16
ACP Racing
lucky14
posted September 11, 2007 05:18 PM
OK there were rumors of a naked bike.
This one is HALF-NAKED!!!
Who stole the other half of the fairing???
posted September 11, 2007 05:26 PM
ya that is about a freak design
GUNNER
posted September 11, 2007 05:43 PM
The whole damn thing is ASS ugly.. Don't make me come down there Steve
zx12adam
Member
posted September 11, 2007 05:44 PM
It's official, all the Literbikes for 2008 are ugly(except the MV).
Onto something important, can't wait to see how they measure up in performance, we only have about 6-7 more months until we get some solid numbers and back-to-back comparisons.
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
posted September 11, 2007 05:49 PM
lmao...ok...but like adam posted.... "performance!" :P
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.24426198005676 seconds processing time
