BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Extended ECU Testing NEW TOPIC NEW POLL POST REPLY
shiphteey
posted August 02, 2007 09:54 AM
Threw it on today....(thanks 13killa!)....gearing is 17/46....got out on the hwy....revved it up high in 4th gear....eyed the tach....
About 12.7-12.8k on the rev limiter...hit it twice for good measure so the GPS would register
163 MPH!!!
I'll throw on the stock ecu and test out the stock rev limiter in 4th just to see.
200 rpms shy of the 13 mark on the tach...time for the 6R tach, hahaa
A.
supra5677
posted August 02, 2007 10:32 AM
is this RR rev limit mod or the clock crystal mod?
nox
PMRA / TMRC Super Street 4022
posted August 02, 2007 11:27 AM
Sweet, I am going to do mine this winter.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted August 02, 2007 12:27 PM        Edited By: entropy on 2 Aug 2007 13:28
ship,
did you ever doubt it???
I have brought my rpm up to 12.1k (real) or so many times on the dyno using the DaveO modd'd ECU. I'd prefer to use the RR reprogramed ECU, but for a lil bit longer the clock mod does the trick.
shiphteey
posted August 02, 2007 01:00 PM
Supra, I think its the clock crystal mod...not sure what that is. Bought it from 13killa on 12org. I like it because the gearing helps offset going -1 up front. Busas are (on paper) geared for 163 at the end of 4th (stock gearing). I will test the difference in MPH w/this gearing and the stock ECU hopefully by tomorrow.
Karl, never doubted it, but I bought the ecu used, and the seller I don't think had it that high, so I had to test it and didn't want to just go with what the tach showed (figured there was a snowball's chance in hell that it could show the tach higher but not have actually raised the real RPM...hey....you never know....and I'm sure its fine now, but nothing like a little real world proof w/GPS so people can see the physical actual differences in MPH per gear....
Knowing it can go 163 in 4th, I'm going from 17/46 to 16/44 soon, should be good for about 160 give or take...perfect if I go w/the 60 shot as 155 is the best mph I've seen in the 1/4. I think I can go 156 or low 157 with full double bottles in the 1/4 on a cool day w/a 40 shot though....
Going to the strip in 2 weekends....would like to see 9.5s n/a stock wheelbase and spray it to 9.3s!
A.
supra5677
posted August 02, 2007 04:10 PM
ya I have the same mod.. the only thing is, is that the injector pulse is shortened by 5% leaning out the mixture..
shiphteey
posted August 02, 2007 05:03 PM
by how much a/f-wise? Is is detrimental in my set-up? I run pig rich off spray so I should be fine, even w/the small shot. Getting a data aq too. I do have the muzzy fuel pump now...duty cycle on a 40 shot maxed out at 80% @ right before the stock rev limiter on the dyno. I'll have to remember to fill out the next fuel cell in the pc3 now that it goes higher, although I think I already did in anticipation of this ecu.
supra5677
posted August 04, 2007 01:50 PM
Iv'e been running it for a couple of years now... Does indeed extend the rev limiter, but it shortens the injector pulse by 5 %.. So now your running 5% LEANER everywhere all the time.. a bandaid would be to add 5 % more fuel to the PC3
shiphteey
posted August 04, 2007 03:15 PM
Thanks for clearin that up. I should be fine given my rich map, at least off spray!
A.
0.22661781311035 seconds processing time
