BIKELAND > FORUMS > ZX12R ZONE.com > Thread: front suspension knocking on zx 12 2004 NEW TOPIC NEW POLL POST REPLY
stef12rr
posted July 26, 2007 02:25 PM
i would like to know if somebody had a front suspension knocking , let me explain! when i take the bike for a ride and i going at low speed a hear knocking, comming from the front of the bike, at first i taught it was my the sterring bearing, it is not .
i think is comming from the suspension and i don't know what is it?
if sommebody know what is it! i will appreciate
thank
thekaz
spell chequer is bustimicated
posted July 27, 2007 07:47 AM
loose brake pads along with alittl runout ?
Mine does the same thing but have yet to find anything wrong other than alittle runout on one of my discs and one of my new brake pads does fit the pin as well as the other three
tcchin
posted July 27, 2007 12:50 PM
The four-pad calipers tend to wear, allowing the pads to rock. Also, the pads are retained by a single pin, which cannot react out a moment like the two-pin setups can. The clunking noise is the backing plates striking the caliper.
capt10ed
posted July 28, 2007 05:15 AM
I think if you put an aftermarket pipe on the bike your problem will be solved.
and 204.5 in the mile.
stef12rr
posted July 28, 2007 05:22 PM
Sorry my english is sometime rusty what do you mean by PIPE
tcchin
posted July 28, 2007 06:28 PM
I think he means that you won't be able to hear the clunking any more.
thekaz
posted July 28, 2007 07:11 PM
aftermarket exhaust system :P
BUT I have a D&D an can still hear it.....
scorpion king
posted July 29, 2007 06:04 AM
Had the same sort of sound.....
Found it to be the ram air intake tube. It vibrated and made a very loud rattling sound at slow speeds.
Take apart your fairings. Put some anti-chafe tape along the edges of your parts to cushion and silence the rattling and put it all back together tightly... sound gone.
Hope this helps.
0.40292406082153 seconds processing time
