BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Somrbody Help NEW TOPIC NEW POLL POST REPLY
supra5677
posted June 30, 2007 06:01 AM
Somrbody Help
Does anybody know how to drag the zx12r maps into the Enginuity Software? Everytime I tryi I'm getting an error message..
supra
ridgeracer
posted June 30, 2007 07:44 AM
I also sent this to you in an email but thought I would post it here for everyone else.
Before the software will work you need to load the definition files.
Start the software and select ECU Definitions.
Select ECU Definitions Manager
Select ADD...
Browse to where you copied the maps folder of the CD I gave you. In the maps you will find a folder called definitions.
Select zzr_defs_002.xml
Select Save
Now click on the open file icon
Browse to your map image file.
As I find new tables I will post updated zzr_defs_nnn.xml files. You will need to go to the Definition Manager and REMOVE the old one and ADD the new ones for them to work. I'm working on a zzr_defs_003.xml right now.
supra5677
posted July 01, 2007 06:55 AM
sorry I'm totally ignorant when it comes to this kind of stuff..
1) Which open file icon?
2) Which map image file?
should I have the Enginuity software open while I do this..
posted July 01, 2007 10:36 AM
Woo-HOO!!!!!!
It works!!!!
Select ADD...
Select Save
ridgeracer
posted July 01, 2007 03:14 PM        Edited By: ridgeracer on 1 Jul 2007 16:16
On the CD-Rom I sent you is a directory called Maps. Copy the entire folder and its contents to My Documents.
Start the Enginuity software.
From the menu bar select ECU Definitions: ECU Definition Manager
It will show the default definition file that comes with the Enginuity software; ecu_defs.xml. Select Add...
Go to My Documents, Maps, Definitions and select zzr_defs_002.xml. Click on Open
Back at the definition manager window click Save
Now click the open image file icon
Go to My Documents, Maps and select the image file (.bin) you want.
It should take a couple of seconds to load and you should be ready to go.
The map001.bin is the map currently loaded in your ECU.
psycho1122
posted July 01, 2007 07:21 PM
Bitchen' Shit!!
supra5677
posted July 02, 2007 06:18 AM
ok cool... In the end I think we will all be uploading a modified version of the 1065 or 1069 ECU... I saw a posting somewhere where an 00 dynoed at 170RWHP bone stop because it was "fitted with a friendlier ecu"
Nikko G pack has a 00 restricted in gears 2 and 3 via ignition and injection.
To date the 02 ZX12r seems to be restricted in gears 1.2.3. and 5 and 6!
1st gear too much ignition
2nd and 3rd gear ignition and injection (nikko g pack)
5th and 6th gear something missing in RR gear position sensor chart
we shall see..
0.237380027771 seconds processing time
