BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cant get my power commander to work NEW TOPIC NEW POLL POST REPLY
posted June 26, 2007 07:54 AM
several tries on and off the bike now, and I cant pick up the power commander with the computer. I have the correct software downloaded from dynojet (for the A modles 2000 and 2001) for the PC3r
Im assuming it has the zero map (or map for a stock bike)in it as it didnt make any difference at the drag strip.
I have a full Muzzy pipe sitting beside the bike and a Muzzy fan on the way and I need to get another map in the bike when I loose the stock header!
if it means anything, im looking at it right now and its been plugged in for a few min to a 9v power source (off the bike) and the little LED has moved up from the bottom (lean) to just above the middle(towards rich). it does the regular little "light show" when its turned on, and the LED at the bottom turns on(lean) then it creeps up (towards rich)
the sticker on the bottom of the pc reads:
204-310
2-07-06
on the back the sticker reads:
M204-001.Map
(map for stock bike)
Any tips???? I dont want to blame someone for ripping me off yet, I want to get this to work!
thx
Scott
ninja12
posted June 26, 2007 12:11 PM
sounds like a button may be sticking.
use your finger nails to pull up on each button on both sides.
Good luck.
ZXLNT
posted June 26, 2007 07:44 PM
Do you have the correct comm port selected???
posted June 27, 2007 06:52 AM
The PC3R "MUST" Be plugged into your bike and "YOUR BIKE RUNNING" for it to work and see it on your computer. once you see it, you can use the Kill switch and up load a map but it MUST Be running to start!
Megabyte
posted June 27, 2007 11:31 AM
Yes, and once the software sees the PC3r, you can hit the kill switch if you want to set the TPS.
Megabyte
posted June 27, 2007 02:54 PM
Xactly
ninja12
posted June 28, 2007 07:26 PM
it's been a minute but i believe you can hit the starter ,
when the headlight comes on the pc3 is energized.
posted June 30, 2007 07:06 AM
thx guys, ill be doing this the right way next time lol.
probly wont be for awhile tho as im having some major clutch issues now......
0.24153590202332 seconds processing time
