BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Starter problems NEW TOPIC NEW POLL POST REPLY
silverzx12r
flu by u
posted June 17, 2002 06:38 PM
Starter problems
A few of us zx-12 owners over on easy's site are having the same problem with our bikes, I do not know about theirs but mine has a pc3r on it, here is the problem: bike turns over normal, then real slow like the battery is dead, and then jumps back to normal, has anyone experienced this? if so what did you do too fix it?
  Ignore this member    Click here to visit silverzx12r's homepage. Click here to send silverzx12r an AIM message.
zxrcy
posted June 17, 2002 07:57 PM
Starter problems
I have the same problem. PC3R with full Muzzy on a 2000. The problem seems to be intermittant. I have been tuning the fuel map a fair bit recently and it hasn't done it in a while. The starter seems to drag as if it is binding or the battery is low and then suddenly it kicks in like normal. I wondered if it has anything to do with the PC3R affecting fuel enrichment at startup causing a momentary compression lock ???? I have noticed that it rarely happens when starting cold. It is usually on a warm start.
GreenGlenn
Ron Jeremy's Stunt Double
posted June 17, 2002 10:37 PM
Hell, my bike is as stock as they come and it happened to me at Gap3. In the AM on the first start it would drrraaaaaggggg the first few button presses and then spin and fire fine after a few more attempts. Dunno...
Glenn
If you love your bike, set it free. If it comes back to you....you probably highsided.
Y2KZX12R
CompetitionCNC.com
posted June 18, 2002 01:59 AM
Sounds like the starter isnt getting enough amps.
There are several battery connections on the 12r.
I'd pull the battery out of its hangar and check ALL the connections.
kawair
posted June 19, 2002 04:14 AM
starter ?
This seems to be a very common problem, showing up on modified as well as completely stock bikes. One idea posted was to be sure your fuel pump had run, pressurized and shut off before hitting the starter button. Another idea thrown out was that it may be a poor OEM quality starter relay. Whatever it is, many people have complained about this.
0.25104808807373 seconds processing time
