shiphteey
posted May 09, 2007 06:08 AM
0W oil...anyone used it in their 12?
Any feedback? Supposed to free up 1-2 hp but not sure how much more wear there would be inside the motor. Mainly for 1/4 mile and 1 mile runs.
I have seen 0W-30 or 0W-40 and was thinking about giving it a shot.
A.
posted May 09, 2007 07:44 AM
why would you do it???
i thought that the 1st number was an indication of cold viscosity, and the 2nd of hot viscosity.
so a 0W-40 would crank over easier, but at operating temp would act like 15W40.
I'm no oil expert fo sho
If Mountainmotor is around, he sure knows.
shiphteey
posted May 09, 2007 08:05 AM
Karl,
Maybe it was 0W-30...not sure of the exact 2nd number . I remember Sport Rider or some mag doing a shootout and ran it in the gixxer thou and got 1-2 hp to the wheel. I would presume that the big 12 could match those type of gains if not slightly surpass it if making big HP (big motor, nos, etc).
The theory being thinner, lighter oil would free up a couple of ponies in the motor.
A.
posted May 09, 2007 09:25 AM
There are some here that have run as light as 20 weight Oil (Top Number) remember the Bottom number is the real weight of the Oil and what you will have when the Magic goes away. Straight 30 weight requires a little more time and care to warm up, but that is what I would consider. Remember, the depth of the Pocket on the depth of Performance!
tcchin
posted May 09, 2007 10:21 AM
The first number in a multi-grade oil refers to its winter-conditions pour point characteristics and the second number refers to its viscosity at 100C. That means that a 0W-40, a 15W-40 and a straight 40 would all have similar viscosities at 100C. Above and below 100C is a different matter entirely.
Oil viscosity requirements are driven by the geometry of the bearings (among other things), with looser clearances requiring higher viscosities (all other variables held constant). Several of the factory-level superbike teams had oil-related issues in their race motors and had to use oils with hot viscosity ratings well beyond what is recommended in the service manual.
I have seen an 0W-30 from one brand outperform a 10W-30 from another brand on the dyno, but the additive packages and base oils were worlds apart.
posted May 09, 2007 12:35 PM
REALLY light oil has been pretty common in 600SS drag stuff, but I personally wouldn't do it on an LSR bike. You can't beat something like Motul 300V for best power with full engine protection.
IMHO....
posted May 09, 2007 01:26 PM
quote: REALLY light oil has been pretty common in 600SS drag stuff, but I personally wouldn't do it on an LSR bike. You can't beat something like Motul 300V for best power with full engine protection.
IMHO....
AMEN to what he said!
I use a lot cheaper Motul E-Tech 100 which is 1/2 Ester Base and 1/2 Pao Base which make it good for street riding also.
There is a real difference in Oil and when I was breaking in my rings for about 50 miles and was using ND 30 (SA Rated Oil) I found that I had a Clutch Basket Spacer in backward that I Never had any problem with (Because I had ne metal in the Oil and did the Stupid deed twice with the Tapered side Out and the Flat side rubbing the Clutch Bearing.)
When I drained the SA Rated Oil I saw some metal and started looking. Remembering that I had this spacer in Backward (Never seemed to have time to turn it around before) I pulled the Basket off to see that it had tried to weld itself to the Bearing. This caused me to take the engine out and split the cases to replace the Bearing and spacer. Good Oil can save an Idiot and Bad Oil cannot save a Genius
Back in the day of Caster Oil, some of the Hill Climbers that rode Indians and Harleys would fill the engine and transmission with This Oil and run the engine to warm it up. then when cool drain the transmission and run the Hill. This saved the Drag of trhe oil in the gear box. So as one person said, there is No performance in Oil, Just a Lack of performance (Oil will not give you power, it will just allow you to keep what you have)
rac4it
Bergie
posted May 10, 2007 01:11 PM
I ran Mobil-1 0W30 at Maxton many times over. That said, I noticed NO DIFFERENCE vs. 10W30 Synthetic Motul. The lighter weight didn't do anything for Maxton.
posted May 10, 2007 01:51 PM
Where HAVE You been Bergie?? Good to see that you are still around (The new father of our COuntry)
rac4it
Bergie
posted May 10, 2007 02:09 PM
VH- I'm around; lurking. Time to make a come-back?
madkawboy
posted May 10, 2007 02:50 PM
Edited By: madkawboy on 10 May 2007 15:51
Hey Ali,
I ran 0/10w in my 12 the first time there. Me and the boys each made 7 passes.........twenty one total and that was over 20,000 miles ago.
I was gonna try everything to get my stock bore/stroke bike over 200, and it worked. I doubt the oil was the deciding factor but the bike has lived to tell about it.
I've been using Motul 300V ever since with good results.
Dan
(BTW.....I'm using Zack's computer.............it's faster!)
shiphteey
posted May 10, 2007 05:11 PM
Good info everyone (including Bergie), I appreciate the input. Looks like the 0W oil is on back order for now so 10/40 for Maxton it is. Plus for now I'd like to see the before and after with these wheels and bearings w/out further changes.
A.
ricksgsxr
posted May 11, 2007 12:45 AM
Edited By: ricksgsxr on 11 May 2007 01:58
Not in a 12 but my 1k Alisyn (Brock sells) or Red Line ( Shintz racing has good pricing and selection of Red Line 0w, 5w etc combos) not for the street made 3 hp more with a mix of 0w/10 and 0w/30 the day I tried it.
I was told not to use on the street. If your looking for the last edge at the strip can make or dyno chart use it. The shop had dyno charts on the wall of a 1k, busa and 12 2000/2001 models the 12 and 1k had the least gain both around 4 hp, the busa made a tad over 6hp.
Alisyn is some good oil in any weight just hard to find locally
Tried Miltec-1 link below. l have an inquiring mind and spend endless hour on the net searching topics on coatings/friction reducers very intresting stuff out there! there are some on psychobike.com that swear .10 improvement when applied to the chain, being a friction reducer is always good .10 improvement or not
Some car boards swear by it, I can't find any negative comments...I never dyno'd with it but used in the motor,chain and in still to this day my truck which has 157k miles on it and still running strong. Every order they include a tube of grease so now you can lube your car/truck for free!
http://www.laniganperformance.com/
Miltec-1
Rick
nox
PMRA / TMRC Super Street 4022
posted May 14, 2007 06:49 PM
Call Royal Purple and talk to them.
126mph in the 1/8, stock motor , 175 lb suited rider.........
If oil made no difference, pro stock bike would not be dumping 0 weight oil on the motors, pro stock car either......., there are mid grades you can run, like 5-30, 5 20, 0 -10........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted May 15, 2007 12:45 PM
I do not care that much for French things, but when it comes to Oil, the fact that they dring so much wine has to come into play! Nothing is better than Grape Seed Oil to cling to parts and is one of the reasons (I think) the Motul Oils are a shade of Green. Your bike can sit for Months but no Dry Start up!
nox
posted May 16, 2007 04:39 AM
Royal Purple is the same way........, it sticks to everything.........
It will climb the tranny gears like the little Lucas thing in auto zone........, with the motor upside down on a stand, a month after the motor oil was drained........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
tcchin
posted May 16, 2007 03:30 PM
Royal Purple's Racing-series oils have really impressive additive packages, as evidenced by their VOA's and UOA's. We were sponsored by them in 2003 and found their racing oils to be superior.
nox
posted May 16, 2007 07:21 PM
Its all I have ever ran.........
After hundreds of passes , I checked the valves......., no adjustment needed., bearings are in great shape still.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
