BIKELAND > FORUMS > ZX12R ZONE.com > Thread: just dynoed 2 NEW TOPIC NEW POLL POST REPLY
stef12rr
posted May 08, 2007 09:50 AM
just dynoed 2
Max power 200.3 hp Max torque 105.3 1287CC projet
thank to all the guys that help me with this projet i hope i wont kill my sell
TRNorBRN6001
posted May 08, 2007 12:52 PM
How does it spin up with that lighter crank?
TFA 200MPH CLUB MEMBER!
stef12rr
posted May 08, 2007 02:11 PM
way faster !!
the roll on!! last sunday me an my girl freind we raced a stock Buse in 6 gear an pass it no problem i could not go above 7000rpm because an alarm relay problem an it was not tune yet, i had 190 hp
the bike feel like a 1000cc super bike way lighter !! just that it wort it!! i am very happy
the guys did the dyno like it!! too he ask to do he's crank.
i just order an muzzy advancer mabay i will a little more HP an TORQ
crank down from 25 lbs to 20lbs an the balancer ( 2 lbs) is out too, 3/4lbs less on the fly wheel
that's how must weight down.
hot cam on in at 105.0
an my stock intake cam on ex side ( but it will not fix unless you machine the extérieur side of the lob) aju. to 105.0 too
thank guys
for the good advice
stef12rr
posted May 08, 2007 02:38 PM
i send my dyno chart to entropy i would like if you can analyze it there something the torq curve then i don't no about
thank
TRNorBRN6001
posted May 08, 2007 02:47 PM        Edited By: TRNorBRN6001 on 8 May 2007 15:51
Cool, That motor should like a little more advance. Hope it'll feel like a turbo bike with creep!
posted May 08, 2007 11:36 PM        Edited By: entropy on 9 May 2007 08:38
deleted, photo too small
tcchin
posted May 08, 2007 11:50 PM
Note the STD values instead of SAE.
posted May 09, 2007 01:17 AM
lets try photobucket
posted May 09, 2007 01:21 AM
what's the diff between the 2 curves, same day 30 min apart and the tq peak moved trom 8200 to 7800 & jumped 5 ft-lb???
posted May 09, 2007 05:22 AM
that torque curve is pretty flat (in a good way) for a BB motor, I thought they were a little more peaky on the torque side? or I could be thinking about something else...
great #'s!!!
MM
psycho1122
posted May 09, 2007 06:10 AM
Looks like it received more fuel at Peak VE.
NICE!
supra5677
posted May 09, 2007 06:56 AM
Peak power at 11,200 wow!! I wonder how 105/107 cam timing would change the curve?
None the less very impressive...
stef12rr
posted May 09, 2007 01:30 PM
i just got a copie of the SAE copie of the dyno 195.5 hp for 102.9 tor.
what is the difference between SAE, STD
hat torque curve is pretty flat (in a good way) for a BB motor, ( sorry i don't anderstand)
is there any 1287 cc mapping from somebody to compair
stef12rr
posted May 09, 2007 01:34 PM
he took a break loll
capt10ed
posted May 09, 2007 05:57 PM
Numbers look good....What numbers do you have the cams degreed in at?
and 204.5 in the mile.
supra5677
posted May 10, 2007 07:15 AM
sae is typically 4.4 to 5 % lower.. std correction factor assumes 59 degrees or below..
posted May 10, 2007 01:04 PM
here's the defn i have
SAE = corrected to 29.23 InHg of dry air and 77 F
STD = corrected to 29.92 InHg of dry air and 60 F
(STD will always be about 4 % higher than the SAE)
Uncorrected = no correction factor has been applied
stef12rr
posted May 10, 2007 05:32 PM
105 int 105 ex
ZXLNT
posted May 10, 2007 10:20 PM
great #'s!!!
MM
Mike, my 1270 has a fairly flat/wide torque curve as well, at least for a 12R..
F_Sik
posted May 14, 2007 12:39 PM
nice and i dont like 12s
As long as y'all don't have any kryptonite/I'm gonna be alright.
  Ignore this member    Click here to send F_Sik an AIM message.
posted May 14, 2007 12:55 PM
CLASSIC "left handed compliment"
Texas12R
posted May 14, 2007 06:15 PM
now thats funny
0.24637317657471 seconds processing time
