BIKELAND > FORUMS > ZX12R ZONE.com > Thread: zx12r vibration at about 4500 rpm NEW TOPIC NEW POLL POST REPLY
buck20
posted May 01, 2007 04:22 AM
is the vibration or buzz normal for these bikes at about 4000 to 5000 rpm.
posted May 01, 2007 04:26 AM
normal (in my experience)
buck20
posted May 01, 2007 04:52 AM
I am happy to hear that I just got the bike and it only has 8000 mi on it but I thought it was comming apart.
buck20
posted May 01, 2007 05:08 AM
now that I here it's normal is there any thing that can be done to dampen it a little or screw it just blow thru that rpm range.
zx12mark
posted May 01, 2007 05:34 PM
it's a hot rod type of machine.it 's just talking you ya.
it is saying we can go alot faster than THIS .
drryanscarsella
posted May 02, 2007 04:29 AM
I fixed my 5 k buzz by lining the inside of where the windshield touches the upper with some felt then reinstalling the screen. Mine buzzed at 5 k a lot and i finally started looking to the cause. Mines a b model and the way the tabs slide in at the bottom isnt very tight to the upper. With a puig screen you have to add two screws at the bottom which changed the buzz a lil so then I lined the upper with something to dampen it a bit and retightened and havent had the vibration since. As an aside, when removing the screen you may see an area of the plastics or screen that looks like it has been rubbed, start there and see if it helps.
tuusinii
posted May 02, 2007 12:10 PM
It will buzz, but adjusting your throttle bodies to good sync and adjust ingTPS and power commander (if equipped) very carefully and the buzz will be smaller. Or just ride faster
buck20
posted May 03, 2007 12:01 AM
What does the wind screen have to do with the motor vibrating! what does TPS stand for.I think I'm going to have to ride faster. In Arizona we ride very fast anyway , It's all we have there are very few twisteys here.
tuusinii
posted May 06, 2007 05:54 AM
TPS is Throttle Position Sensor. It's that little black thing on Your throttle bodies left side that has wire going to it. Check the service manual or browse trough web to find detailed istructions.
0.24383997917175 seconds processing time
