BIKELAND > FORUMS > ZX12R ZONE.com > Thread: BATTERY PROBLEM NEW TOPIC NEW POLL POST REPLY
JAN ZX12R
posted April 18, 2007 12:32 AM        Edited By: JAN ZX12R on 18 Apr 2007 01:34
BATTERY PROBLEM
I BOUGHT THE 2002 ZX12R BIKE AND THE BATTERY WAS DEAD, I FITTED A NEW ONE BUT IT ONLY LAST 3 DAYS AND IT WAS DEAD AGAIN,WHAT CAN BE THE PROBLEM?
ZXLNT
posted April 18, 2007 05:24 AM
Sounds like a charging problem to me, stator or rectifier..
g_right
posted April 19, 2007 04:24 AM
I had the same thing happen to me with my 00...also my headlights would not come on when I would jump it off...I fried the RECTIFER PLUG AND SOCKET!!!!!!!!
  Ignore this member    Click here to send g_right an AIM message.
JAN ZX12R
posted April 19, 2007 06:40 AM
O ok thanks guys,whats the price of that rectifier?
ZXLNT
posted April 19, 2007 09:04 AM
I have a few spares 60 TYD..
g_right
posted April 19, 2007 12:07 PM
I don't know...pull the plugs first and look to see if they are melted or not getting a good contact.
ZXLNT
posted April 19, 2007 06:57 PM
Sounds like the logical thing to do..
JAN ZX12R
posted April 20, 2007 07:04 AM
Ok thanks guys ill do that and keep u posted.
zx12mark
posted April 20, 2007 08:44 PM
change the oil in your stator plugs.
JAN ZX12R
posted April 23, 2007 06:47 AM
Ok ill try that,thanks alot.
g_right
posted April 24, 2007 04:17 PM
Did anything work for you yet?
JAN ZX12R
posted April 25, 2007 07:23 AM
I took the bike to a shop,they changed the stator and rectifier no luck,still not charging, its running on 11.9v and is suppose to run at 14.something.
posted April 25, 2007 09:18 AM
NOW THAT"S FUNNY!
ZXLNT
posted April 25, 2007 09:29 AM
Weak magnets in the flywheel rotor??
Not common by any means, but not unheard of either. Have them check the stator output...
posted April 25, 2007 12:19 PM
This guy is being funny on an inside Joke! Kawasaki has had all sorts of problems with the Stator Plug leaking oil from the engine. To get to this plug, take off both seats and on the Left side of the bike under the rear cover there is a Rectifier that has 2 sets of Connectors. Take them apart and if you see ANY Oil, you have this problem also.
Take Brake Cleaner and seriously clean these connections and plug them back together If your problem goes away, then keep an eye on this area because it can leak Oil on to your rear tire. Kawasaki did a recall on this and the fix was not perfect to say the least. Let us know what you find
g_right
posted April 25, 2007 04:17 PM
Oh yea Vincent, I had that same problem on my 00 when I first got it.......
JAN ZX12R
posted April 26, 2007 06:39 AM
I CHECKED THE PLUGS IT WAS DRY, THE FUNNY THING IS WHEN I DISCONNECT ONE OF THE HEAD LIGHTS THE TESTER SHOW A NORMAL CHARGING RATE.
g_right
posted April 26, 2007 08:37 AM
Can you keep the head lights out for a while?
and see if it will keep a charge..
posted April 26, 2007 09:02 AM
You may want to check the Bulbs and see if they are the 100W Kind? 200 Watts vs 100 Watts and slow driving COULD make a difference and maybe the wires Heated up and drain voltage, so look there!
JAN ZX12R
posted May 02, 2007 06:22 AM
OK I KEPT THE HEADLIGHTS OUT AND IT KEPT CHARGING.ILL CHECK THE BULBS THANKS.
maximus
posted May 02, 2007 04:42 PM
I believe they had a recall on it, they repaired mine on my 2003 zx12r for free under the recall.
JAN ZX12R
posted May 06, 2007 07:17 AM
I fitted new globes and it kept charging,the old ones was to strong,every thing is fine now,thanks guys!
g_right
posted May 06, 2007 06:03 PM
Good great...now go get some seat time.....
0.25742697715759 seconds processing time
