BIKELAND > FORUMS > ZX12R ZONE.com > Thread: ZX12R overheating seizing NEW TOPIC NEW POLL POST REPLY
stevehop
posted April 09, 2007 11:04 AM
Does anyone know if there has been any overheating and seizing issuses with ZX12 motors. I have been told that when these engines have been fitted into race car applications that these problems surface?
Wideout
posted April 09, 2007 12:09 PM
Only experience here with that application, is Five-0. Look for him on here and send him a private message. That question as it applies to the bike is too broad to be answered.
Wideout
posted April 09, 2007 12:13 PM
http://www.bikeland.org/board/member.php?action=viewprofile&UserName=five%200
posted April 09, 2007 07:38 PM        Edited By: dougmeyer on 9 Apr 2007 20:40
If the radiator is at least as large as the bike rad and is properly placed to get the air in and, more importantly, OUT, they will cool just fine. The engine doesn't know ift it's in a bike or a car, doesn't care where the torque is going. The air flow thru the rad. is the biggest factor.
Texas12R
posted April 10, 2007 10:53 AM
I just remembered that some have posted that they had cooling issues that ended up being
pockets of air caught in the system.....may not be your problem but it is a possibility....Michael
rjbrookes
posted April 19, 2007 04:14 PM        Edited By: rjbrookes on 19 Apr 2007 17:15
hi
i have a zx12 in a kit car and yes i did get cooling problems. the initial setup was with a car rad and car water pump - one off an opel/vaxhaull astra.
countless days, money, hassel and bloody eventually found the problem to be the water pump.
I think a bike runs on 2 litres of water (i think) and my setup runs about 5, the installed pump simply couldnt cope with it. The car is mainly a track toy, doing 45 mins a time at full gas!!! with the new pump fitting .....a Craig Daivd EWP 80 the water temp remain steady at 100 degress (212 F)
the rad seems not to be the issue its the rate at which the water flows around.
Russ
edit.. pockets of air and lack of water will no doubt cause problems - i have got the t shirt to prove it pre and post this new pump
posted April 26, 2007 10:44 AM        Edited By: dougmeyer on 26 Apr 2007 11:45
I can't over emphasize--
Most cooling problems in car installs result from inadequate airflow through the rad, and the most often part of that is getting the air OUT of the radiator, not into it.
Those David pumps are nice.
supra5677
posted May 09, 2007 09:27 AM
try adding a larger oil cooler than that tiny one that goes with the filter..
five 0
posted May 10, 2007 05:15 AM
Air Flow
Your right about air flow. If the radiator is in the front of the car you must have a good shroud for the fan!! I moved mine to the rear and it ran so cool I would have to turn the fan off under caution laps. Alittle scary having the hot water just above your right shoulder, but it works great.
5-0
0.27304410934448 seconds processing time
