BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 1361 at the strip NEW TOPIC NEW POLL POST REPLY
mack
posted June 02, 2002 06:45 PM
1361 at the strip
On a nice hot 90 degree at about 85% humidity a weak ago I ran a 9.15 at 150mph.Looking for an 8 sec run soon.Just thought you all would like to know.
PaulVincent
posted June 02, 2002 06:52 PM
Something tells me that you'll get it and then some.
Zhooligan
Post Whore Extraordinaire!
posted June 02, 2002 07:08 PM
Nice run. Things happen a little faster in that zone!!
future; -- Youth is forever.
mrfast
posted June 02, 2002 07:11 PM
Sounds great,what are your 60' times? HP? Did you install the stroker at the same time as the pistons? Just wondering if the stroker is as noticeable an improvement as the piston kit.
posted June 02, 2002 07:23 PM
I've got both a 1270, and a stroked motor. The 1270 feels as pipey as the stock bike, the stroker comes in lower, and signs off near redline.
mack
posted June 03, 2002 11:55 AM
60ft 1.518 330 3.924 1/8 5.919 mph 122.24 990 7.617 1/4 9.154 mph 150.90 The kit was installed all at the same time.It does have air shift,lock up clutch,slick,wheely bar,3inch arm,and17/49 gearing.
madmike
posted June 03, 2002 12:33 PM
how much do you weigh and any other goodies on the bike??
Mad Mike..
Good luck on the 8's Im not to far behind you...
mack
posted June 03, 2002 06:38 PM
My weight 165lbs.A shift light,scotts damper,and a muzzys sidewinder.I have the bike pretty low,I even removed all foam from the seat and just glued some materailon the plastic base.I will try to post some pics soon.
krexken
posted June 03, 2002 06:54 PM
Cool. Little more practice and I'm sure you'll be there. Like to see the pics when you get em posted. I need ideas!
posted June 04, 2002 02:38 AM
Mack,
you have it knocked!!! twist that MoFo, she'll carry you into the 8's. Must be cool not having to worry about wheelies!!!!!
give us 1361 owners some more info on yr motor, like cam settings, any porting? how many passes/?
mack
posted June 04, 2002 08:29 PM
Do not have a lot of time to night,but its getting better.9.09 at 153.
0.26942086219788 seconds processing time
