BIKELAND > FORUMS > ZX12R ZONE.com > Thread: if using block off plates what do you do with.... NEW TOPIC NEW POLL POST REPLY
sndnga
posted March 28, 2007 12:41 PM        Edited By: sndnga on 28 Mar 2007 14:15
the vent comming off the back of the frame on the left hand side? leave it as it is? according to the instructions for the clean air mod this vent is routed back to the front and connected to the hoses sitting on top of the valve cover if your doing the mod without block offs like Blitz's instruction. Is this step not needed if using block offs? Someone clarify thanks.
posted March 28, 2007 02:07 PM
just block it off or put a vent to it...
sndnga
posted March 28, 2007 03:02 PM
the fact that it exists means its already venting. what your saying doesnt make sense complete opposites.
shiphteey
posted March 28, 2007 04:42 PM
Sndnga...my bike has all the fairings off.....early next week when I get back from Maxton you can check it out and see how mine is set-up unless you have time thurs night. I'm in fairfax off of 50.
A.
sndnga
posted March 28, 2007 05:53 PM
hey bro i wish i could make it but thats not going to be possible this thursday. if you got time if you could just look at it and see that would help as i got my bike apart at the moment and I just want to get it back together. i posted this on the other site but didnt have any luck. What the hell happened to Blitz? is he here now? if he is get that sucker to take a look here and post some much needed answers.
blitzkrieg
Road kill = Free lunch.
posted March 28, 2007 07:25 PM
Sorry, been away for a while.
If you are talking about the vacuum feed that went to the kleen air, you plug it.
Look for photo and caption "f" on the doc.
I posted it years ago on "the other site". Is that what you are talking about?
http://www.zx-12r.org/Motorcycle_info/Information%20Pages/KleenAirRemoval_CrankCaseMod/Kleen%20Air%20Removal%20With%20Crankcase%20Vacuum%20Procedure.htm
If you are using the Muzzy Block offs (I did on my 12) the doc is:
http://www.zx-12r.org/Motorcycle_info/Information%20Pages/Kleen%20Air%20Removal%20Project/Bike_ZX12_Maintenance_index.htm
sndnga
posted March 28, 2007 09:11 PM
No im not talking about the vacuum feed that goes into the throttle bodies. actually im talking about caption "H" in the first documented procedure where you didnt use block offs. Is "H" ignored all together when using block offs? you dont mention anything about it when using block off plates. If so why ? Thank you.
shiphteey
posted March 29, 2007 12:34 AM
I will post up some pics...you should too to give us a better understanding if you can.
A.
oof440
posted March 29, 2007 04:21 AM
That is the crankcase breather. If you are just going to use block off plates there is no need to mess with it you can just leave it hooked up. As you know the frame on the zx12 doubles as the airbox and if you just leave that hooked up it will just continue venting the crankcase breather into the airbox just like it does from the factory.
sndnga
posted March 29, 2007 06:30 AM        Edited By: sndnga on 29 Mar 2007 07:33
ooof: thanks
shipteey: if you look at Blitz's 2nd link you can see what im talking about in caption H. This where im getting confused because there is no mention of this in the procedure using blockoffs.
blitzkrieg
posted March 29, 2007 02:05 PM        Edited By: blitzkrieg on 29 Mar 2007 15:07
You are confusing yourself.
The first link above is the kleen air removal WITHOUT using Muzzy block off plates (using the kleen air reed valve covers effectively as the block off plates) AND the crankcase vacuum mod. That is Ergos bike.
The second link above is the Kleen Air removal WITH using the Muzzy block off plates WITHOUT the crankcase vacuum mod. That is my bike.
The crankcase vacuum mod is a completely separate mod from removing or disabling the kleen air.
The intent of the cranckcase vacuum mod is to introduce a negative vacuum in the combustion chamber.
If you are going to create a vacuum in the crankcase you have to effectively seal it off. That is what is taking place in caption "H".
If you are NOT doing the crankcase vacuum mod but just installing Muzzy block offs, don't even look at the first procedure, look at the second one only.
H2 to ZX12
two stroke power
posted March 29, 2007 02:49 PM
that's too much work for a 1-2 hp gain, now go make me a sammich
  Ignore this member    Click here to visit H2 to ZX12's homepage.
blitzkrieg
posted March 29, 2007 07:15 PM
I actually didn't do it (the crankcase vacuum mod) because there were several guys that experienced a flickering oil pressure light on idle after doing the mod.
Now, I can't say if that was due to some affect that the vacuum had on the oil pressure switch (can't see how) or what, but me no likey that....
Nonetheless I documented the procedure for those that wanted to do it.
sndnga
posted March 29, 2007 08:31 PM
Blitz:
I did mix the links when talking to shipteey, but regardless of that i wanted to know why the vacuum mod wasnt used with the block off ducument befor i got started. Now i know. Thank you.
0.27009105682373 seconds processing time
