BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Does it matter... NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted March 27, 2007 10:18 AM
Does it matter...
which way the front sprocket goes on?? there are numbers stamped on it,, do they face the motor or face out,, any installation pointers are appreciated! thanks
posted March 27, 2007 10:38 AM        Edited By: entropy on 27 Mar 2007 11:39
i always put the numbers facing out, might save counting teeth.
i install by putting a 2x4 thru the spokes and under the arm, then tq to 94# or whatever the spec is.
I've seen folks just hit it with an impact to tighten, but i sure don't like that method.
Be sure not to forget that lock washer type thing, IMO its needed...
twista
posted March 27, 2007 11:45 AM
you think the 2X4 way is good in removal procedure,, or impact,,it would evidentally have to be in gear that way,, and ive read somewhere that you dont want it in gear etc.. anyone??
aliveagain
posted March 27, 2007 12:11 PM
I used an impact to tighten a sprocket once,only once! In tightening it pulled the trans shaft hard enough to break where the bearing sat in the tranny.Granted this was on a Harley but the lesson was learned.Besides,I like to feel if the threads are buggered.
posted March 27, 2007 12:25 PM        Edited By: entropy on 27 Mar 2007 13:26
in no case would i have it in gear.
The 2X4 holds the wheel from rotating and the chain keeps the f spk from rotating
As AA says, pls do not use an impact to tighten it, but loosening is fine (with trans in neutral)
twista
posted March 27, 2007 01:28 PM
does anyone know which direction the nut comes off,, ie. counterclockwise??
posted March 27, 2007 08:01 PM
normal threads, "lefty loosey" (counterclockwise)
twista
posted March 28, 2007 04:49 AM
Than Entropy!
blitzkrieg
Road kill = Free lunch.
posted March 29, 2007 02:22 PM
Yeah, you hit it with an impact in gear and you are gonna get to learn what a tranny looks like up close and personal.
twista
posted March 29, 2007 03:13 PM
Buzzed it off with an impact,, no problem,, did the wood thing,,off and on,, light tap on the install,, and then the torque wrench to finish her off,, thanx guys,, cant wait to try a 17 toofer!
0.31493592262268 seconds processing time
