BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anyone tried this? NEW TOPIC NEW POLL POST REPLY
iflyguns
posted May 30, 2002 04:49 PM
Anyone tried this?
Hey guys anyone tried this. I have a Muzzy Clutch setup and had some chatter so I took it a part and lightly sanded the plates and fibers cleaned and put back together ONLY this time I put it back without the flatspring and left the larger fiber out that fits over the spring. I got one of my other new fibers from the stock clutch and put it in instead. So, I have all fibers which are the same size and NO flat springs at all. Bike runs the same, goes into gear a little smoother BUT, has a lot less noise in the basket area. What do you guys think????
Tony D
BA
posted May 30, 2002 07:27 PM
I would have sworn that little guy was there to make shifting a little softer, but it looks like you found different!
I'da been too chicken shit to try it. Hope it continues to work out for ya.......
iflyguns
posted May 31, 2002 02:25 AM
I looked at what the purpose of this spring was for before I tried it and the only thing I found in the service manual was that it is called a judder spring and is used to quite the clutch unit.
Tony D
silver01bullit
on here too much
posted May 31, 2002 03:39 AM
I like my Muzzy setup a lot but found that it needed to have some serious adjustment time spent on it (to be expected with performance toys though ) Don't forget you can get a lot of shift feel out of the shift rod adjustment...
  Ignore this member    Click here to send silver01bullit an AIM message.
0.21614599227905 seconds processing time
