BIKELAND > FORUMS > ZX12R ZONE.com > Thread: WHERE DID THE GREASE GO NEW TOPIC NEW POLL POST REPLY
muleskinner
posted March 07, 2007 06:19 PM
Using a hand pump grease gun I pumped about 1/2 of the tube of grease into the fitting on my rear swing arm and could not see any coming out of the side bearing areas. Has anybody here greased their rear swing arm and if so, how could you tell when you had put enough grease in????????
muleskinner
posted March 07, 2007 07:18 PM
I solved the problem. Looking under the "Periodic maintenance" section of my official Kawasaki motorcycle service manual, I found these instructions. " Force grease into the nipple until the grease comes out from the right side of the swingarm pivot."
zx12mark
posted March 07, 2007 09:45 PM
they don't put enough grease from the factory on most bikes it seems.
0.22254991531372 seconds processing time
