BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2005 injectors in a 2002 bike? NEW TOPIC NEW POLL POST REPLY
Seth ZX12r UK
posted February 27, 2007 08:25 PM
Are they compatible?
Alternatives?
Prices?
Thnx
  Ignore this member    Click here to visit Seth ZX12r UK's homepage.
posted February 28, 2007 01:14 AM
seth,
do a forum search on RC370's I went down the path you are headed on. The 370's will fit with a lil modding and prodding, but getting the TB's back on is REAL tight. I did it, but ...
As you know, i have a brand new set of 05 injectors but they are smaller than my 00's bottom line is that 05's won't fit in my 00 and i think that the 02's = 00's..
Seth ZX12r UK
posted February 28, 2007 08:43 AM
seth,
How much modding & prodding?
Whats involved?
Read on another thread doug meyer used some 550cc RC ones?
posted February 28, 2007 04:39 PM
Sort of. We used 550's on a Turbo application, I used 370's on a N/A like Entropy's. No matter- the fit issues are the same. They are worth the trouble, I think Karl will agree.....
Seth ZX12r UK
posted March 01, 2007 04:57 PM
So whats involved in fitting the RC injectors?
Any photos of the 2 different injectors?
Seth ZX12r UK
posted March 04, 2007 08:29 AM
Will a stroked bigbore 12r be ok to run the RC 550cc injectors?
posted March 04, 2007 07:04 PM
You have to space the rail up about 3mm because they're taller. That means the rail just touches the bottom of the frame. On a stocker you can remove the FI rack with the engine bolted into the bike. With the bigger squirts you'd have to tilt it forward a bit . Can you get it out at all, Entropy? I never tried it with the engine bolted in.
Doug.
posted March 04, 2007 09:17 PM
Seth,
I can't imagine what 550's would be like to tune, and 370's get the duty cycle down by 10% so why 550's (unless turbo)???.
Doug,
I had my 370's modded just a titsch so they go a lil deeper into the rail, and the rail isn't quite as tall as it would be.
but even with that mod it is a REAL pita to get the TB's on/off the motor without tipping the motor fwd. I did it once but used up a mo supply of curses & knuckle skin getting it done.
blubyu
posted March 06, 2007 02:51 AM
At what level of modification would 05 injectors be advantageous? Would it do anything for a 02 12 with a 1287 and head work or is it more for the monster motors like Entrophy?
posted March 06, 2007 04:32 PM
I would use the 370's on anything over 190 hp. The stockers will support 200 hp but you're moving towards the edge of a sustainable duty cycle. As I'm sure Entropy will agree getting the ectors down to a 70% duty cycle or so gives a much more tinable set up with a nice stable A/F.
0.22487020492554 seconds processing time
